Originally Posted by
D3nb3r
What PartcleX means is that wag mong palitan ng HID bulb ang halogen bulb na designed with a reflector bowl. Kahit plug-n-play, oem or aftermarket HID bulb is a big no-no na gamitin mo on reflector housing. Unless wala kang pake sa ibang motorist gaya dun sa kilala ni PartcleX. Which is the opposite of what this forum is all about.
Kaya nga if you want HID you have to install the bulb inside the projector hence the retrofit option.
The reason why hindi mo pwedeng gamitin ang HID bulb sa halogen housing is kung titignan mo ang length and physical dimensions ng bulb ay iba. mas mahaba ang HID. Also IMO, yung ligh source ng HID na hallide salts ay iba ang position if compare mo sa position ng filament ng halogen bulbs. Now once ma energize ang bulb ng HID pag tumama ang light sa reflector na design sa halogen iba ang bato na angle ng light since magka iba ang length nila. kaya kung ma notice mo sa naka HID bulb on halogen housing kahit naka low na sila dami pa rin kasalubong na nag flash sa kanila dahil nasisilawan kahit naka low na.
whew haba ah. hahaha.
Sent from my SM-J710GN using Tapatalk
They're hell-bent on sustainability kasi... even at the expense of a shorter lifespan from their...
BYD Philippines
