ask ko lang kung paano ba tanggalin yung bulb socket sa likod ng headlight, papalitan ko kasi ang headlight bulb ko. Pajero Gen II
hinihila lang ba yun basta or may lock pa? ty
*Remove wiring connector
*Remove rubber boot
*Loosen wire clip (diin then pulldown yata)
*Pull out bulb.
Instillation is reverse of said procedure. Make sure not to touch new bulb except at the base.
n while putting in the bulb be careful not to scratch the bulb against the inner housing hole
lagyan mo narin ng konting grasa yun socket ,bago ikabit sa headlight bulb
Clean the glass portion with cotton and alcohol before installing as well just to make sure (you never know if someone touched it before you got it).
