Results 1 to 9 of 9
March 26th, 2004 06:51 AM #1
How do you re-aim headlights? I had busted my left lamp and when I got a replacement, the left one is kinda out of focus.
Actually I'm not really a DIY'er so the correct question is. Which pro does this and how much would it cost me to have it done.
Regards,
March 26th, 2004 01:50 PM #2
I had my lights aligned by CATS EDSA, damage was Php350.00 about a couple of years ago. But, imo hindi maganda ang alignment na ginawa, too high and off-centered. I had to re-adjust everything myself. Pumunta ako sa gas station around 09:00PM and found a flat wall with even surface. Then followed the simple guidelines.
Headlight Aiming click here!
March 28th, 2004 04:10 PM #3
sir... i duno.. if tama ginagawa ko.. but... i just face my car on the wall... then... adjust mo lang headlight.. usualy.. screw lang po yun..
March 28th, 2004 04:10 PM #4
March 31st, 2004 06:48 PM #5
Park your vehicle a foot away facing the wall. Mark the lines where your headlight beam is. Reverse your vehicle 7 meters in a straight line. Follow the guidelines on how to lower and center beam patterns. Ideally, it should be an inch lower and 2 inches to the right. This all depends how your headlight is configured. Whether you have single housing or dual headlight source.
Adjusting it close to the wall will be useless because you can't see how the light beam pattern adjust.
April 2nd, 2004 05:10 AM #6
Naayos na ni Big Berts!:flush: Kahiya sa kanila and Thanks!
Although me crack na daw yung plastic, I will have to replace the whole thing.
Tsikot Member Rank 3
- Mar 2003
- 637
October 8th, 2004 10:06 PM #8
aligning of the housing or tutok lang ng bulb? kaya i-DIY kung tutok lang ng bulb :D
October 9th, 2004 04:22 PM #9
Gusto mo ng high tech? Dun sa Autotechnika (Commonwealth, Fairview), napunatahan ko opening kagabi, I'm impressed with their test lane facilites. :D
China's EV industry concerns. Here's what we know CNBC Television
China cars
