Results 1 to 9 of 9
    Dec 2003
    How do you re-aim headlights? I had busted my left lamp and when I got a replacement, the left one is kinda out of focus.
    Actually I'm not really a DIY'er so the correct question is. Which pro does this and how much would it cost me to have it done.
    Regards,
    I had my lights aligned by CATS EDSA, damage was Php350.00 about a couple of years ago. But, imo hindi maganda ang alignment na ginawa, too high and off-centered. I had to re-adjust everything myself. Pumunta ako sa gas station around 09:00PM and found a flat wall with even surface. Then followed the simple guidelines.
    Headlight Aiming click here!
    sir... i duno.. if tama ginagawa ko.. but... i just face my car on the wall... then... adjust mo lang headlight.. usualy.. screw lang po yun..
    Park your vehicle a foot away facing the wall. Mark the lines where your headlight beam is. Reverse your vehicle 7 meters in a straight line. Follow the guidelines on how to lower and center beam patterns. Ideally, it should be an inch lower and 2 inches to the right. This all depends how your headlight is configured. Whether you have single housing or dual headlight source.
    Adjusting it close to the wall will be useless because you can't see how the light beam pattern adjust.
    Dec 2003
    Naayos na ni Big Berts!:flush: Kahiya sa kanila and Thanks!
    Although me crack na daw yung plastic, I will have to replace the whole thing.
    Mar 2003
    saan shops ba puwede magpa align ng headlights here in qc?
    aligning of the housing or tutok lang ng bulb? kaya i-DIY kung tutok lang ng bulb :D
    Gusto mo ng high tech? Dun sa Autotechnika (Commonwealth, Fairview), napunatahan ko opening kagabi, I'm impressed with their test lane facilites. :D
Re-Aim Headlight
