Results 1 to 20 of 20
    sir saan nakakabili ng magandang ilaw sa loob ng sasakyan?
    The stock bulbs just didn’t cut it.
    parang ganito
    Sep 2012
    Sa itsurang yan mukang LED bulb ang ipinalit.
    You can find those led bulbs, kung sa mall ka maghahanap, Ace hardware, handyman, true value, concorde, blade, etc...
    Sent via Tapatalk
    Quote Originally Posted by jodski View Post
    Sent via Tapatalk
    ok sir ill check thanks
    Aug 2012
    You can replace stock bulb with LED. Just open it up to see what type you need.
    Example, mine uses 31mm Festoon for front and rear dome lights.
    Aug 2012
    The cargo light is T5 bulb. I decided to use LED with T5 adaptor instead of regular T5 LED.
    Jun 2015
    Quote Originally Posted by red_one View Post
    Where'd you find the 6-LED cabin light replacement? Or is it just a sample pic (it looks longer than 31mm)? I only got the 4-LED kind from Blade and, aside from it being white, it's still the same brightness as the stock bulb.
    sent via Tapatalk
    Aug 2012
    Ordered them from D3 Technologies.
    D3 Technologies
    The photo I posted is the same bulbs I ordered. 31mm Festoon with 6pcs 5630. They are way, way brighter than the stock. No discussion.
    Note that not all LEDs are created equal. The newest and brightest now are 7020, 3535 at 5630.
    The problem with LED being sold in the mall is that they do not indicate you what LED they use. They might just be using 3528, 2835 or 5050 which are low lumens.
    sent via Tapatalk
    where can i find these multiple LEDs?
    the ones i see in the mall, have only 1 or 2 LEDs.
    Jul 2017
    Good Day,
    Napapalitan po b ung color ng Gauge/Speedometer light ng Honda City? Sakit kasi sa mata ng orange..
    http://www.topgear.com.ph//images/20...d-Edition4.jpg
    Thanks
    May 2018
    Nakabili ako interior lights sa shopee less than 100pesos pair na.
    Jun 2015
    How much was the 31mm festoon? I didn't get any reply from d3 fb page.
    sent via Tapatalk
    Jun 2016
    Does anyone know the Kelvin of the current crop of Ford Everest? Di sya kasing dilaw nung sa interior ng Fortuner, pero di rin sya puti. Been looking for the longest time for peanut type and festoons of that color. Can't find one - except maybe if I go to Ford. :S
    Jun 2015
    Got mine at Blade sa Rob Las Piñas.
    Tapatalked
    They have those at concorde.
    Sent from my ASUS_Z00AD using Tsikot Forums mobile app
    May 2015
    I bought it sa shoppee. 159 pesos 13pcs. 5pcs T10 5050 5SMD, 4pcs T10 1206 8SMD, 4pcs 31MM 3528 12SMD LEDS. Good buy [emoji108]
    Sent from my Redmi Note 5 using Tapatalk
car interior light bulbs
