Results 1 to 10 of 19
- Oct 2003
- 19
November 4th, 2003 10:24 PM #1[COLOR=darkblue]HeLLo,
I'm driving a Mazda B2500 pick-up. And I want to add some additional lights , which I plan to put it sa front bumper for additional light...
Ano ang maganda ilagay? na gaganda ..at hindi magmumukhang baguy.
If I install this light, do I have to add additional relay for this?Last edited by Paulo; November 4th, 2003 at 10:28 PM.
Unregistered user
- Jun 2003
- 1,121
November 4th, 2003 11:37 PM #2Ano ang maganda ilagay? na gaganda ..at hindi magmumukhang baduy?
--- my suggestion sir if its a b2500 go for hella comets or other driving lights that are similar not too big in diameter and not too thick (but it really depends on your preference after all its your truck)
YES! you have to
also try to look for a switch ( if wala ka pa )one that would look stock would match your dash perfectly
try to go to surplus shops for the switchcheaper\
GoodLuck
- 10,620
November 5th, 2003 11:36 AM #3iba't ibang klase ang mga aux lights, may driving lights, may flood lamps, may fog lights,
and yes you must add a relay
also buy japan switches yung push/pull.
Unregistered user
- Jun 2003
- 1,121
Tsikot Member Rank 5
- 3,144
November 13th, 2003 10:00 AM #5baka sakaling makatulong...
www.hella.com
then proceed to "light tunnel" and test the particular aux lamp
eto yong link, sobrang haba kasi, try na lang if it will work
http://www.hella.com/produktion/Hell...ivingLamps.jsp
September 7th, 2012 02:16 PM #6
my friend is thinking of installing auxilliary lights for their L300FB van.
1. what shape do you recommend? round or rectangle?
2. brand?
3. what size is best suited for L300?
- Dec 2002
- 2,335
September 7th, 2012 02:26 PM #8depends yan sa requirement mo with regards to increase visibility and also your budget. That 500FF is ok, I think meron nayan driving lights (narrow-long) output and meron fog (flood type, short but wide). You need a relay for that or buy a complete harness, mga 1-1.5k set and yung switch inside the cabin.
September 7th, 2012 02:48 PM #9
September 7th, 2012 03:54 PM #10
You can also try bosch.. Merong bosch auxiliary lights na binebenta mismo sa bosch center sa kabignayan near banawe..
Personally gamit ko ay 4 bosch compact 100's... Very happy with the output...
Small yet powerful... Search mo sa net.. So you can have alternatives and comparisons
