Results 461 to 470 of 717
- Dec 2002
- 2,335
July 1st, 2013 12:34 AM #461I'd be careful about making this conclusion.
Osram and Philips make OEM halogen bulbs and one reason why they are oem eqpt is because of the quality they produce and the reproducibility of this quality, i.e there is a standard level of quality for the parts they make.
For sure some China made halogen bulbs can make acceptable quality bulbs for the price. But imo, right now, they dont have the same level of quality as OEM bulbs. Also make sure to compare apple to apple of course. Also output is one story, service lifetime is another. No use to have a bulb with good output and you can only use it for 6 months.
- Feb 2006
- 771
July 2nd, 2013 10:10 PM #462
- Sep 2012
- 194
July 4th, 2013 05:57 PM #463pwede rin siguro magpalit agad to XV or Osram NB to get that extra 15% improvement, then make the stock bulbs spares for emergency? atleast in case of busted bulb during long trips, may readily available spare...
July 15th, 2013 09:13 PM #465
ano mas ok na setup para sa Pajero FM? planning to replace yung stock... and need ba na pati fog lights paltan ko.. mejo malabo din kase mata ko.. salamat po..
- Feb 2011
- 254
July 29th, 2013 07:27 PM #466mga sir kasing lakas din ba ng hid ang buga/liwanag nga Philips X-Treme Vision at Osram Night Breaker Plus?mahina kasi mata ko sa night driving kahit medium tint lang car ko.
- Jul 2008
- 479
July 30th, 2013 08:47 AM #467malayo pa din sa HID sa buga at sa puti. max improvement from halogens is estiamted at 30%. I used Osram nightbreakers plus for Hi beam H7, naka HID projectors ako sa low beam. i recently replaced the ONB+ with sparco white bulbs, mas maputi kaysa sa osram NB+ pero at mas mura pa. parehas lang ng buga.
- Dec 2002
- 2,335
July 30th, 2013 11:21 AM #468Upgrading Halogen Bulbs | HID Retrofit
comparing stock, philips XV and Osram NB
July 30th, 2013 11:43 AM #469
August 21st, 2013 05:45 PM #470
Installed Philips diamond vision for the headlights and xtreme vision for the fog lamps in the Honda jazz. Nice improvement
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
