Results 1 to 10 of 81
January 28th, 2005 02:50 PM #1
Help po... which is better po ba na ipalagay ko sa mitsu adv 2002 model ko, OSRAM or RAYBRIG na all weather headlights? do i still need to put a relay for it? your comments and suggestions are well appreciated. tnx.
January 28th, 2005 02:54 PM #2
original OSRAM or FLOSSER.
I guarantee raybrig bulbs will be busted in less than a year.
As for the relay, if they are the same wattage as stock, no need for a relay. But if you upgrading wattage (like 55/60 to 90/100watts), a relay is a wise investment.
January 28th, 2005 02:57 PM #3
if ur not after porma(white), osram all season oks na oks. if porma, philips diamondvision, white.
January 28th, 2005 03:14 PM #4
are these all season bulbs multicolored? are they really that effective?
January 28th, 2005 03:17 PM #5
yep i have osram all seasons in our cefiro and it looks like multicolored but actually is yellowish when projected on the road. much better visibility than white bulbs but tradeoff is not that porma, stock look kasi.
January 28th, 2005 04:44 PM #6
are narva bulbs ok? kakabili ko lang kasi ng narva stock wattage bulb sa shop ni sir glenn, pero mahina pa rin. i already aligned it to no avail..halos wala pa rin akong makitang beam of light sa daan. is it possible though kahit stock wattage ang mga bulbs eh mas brighter ang ibang brand? like osram, flosser or koito?
SiRaNeko
- Jan 2003
- 973
January 28th, 2005 08:35 PM #7Originally Posted by BlueBimmer
anong wattage nyan 80/80?
thnx
January 29th, 2005 10:46 AM #8
stock wattage lng ung all season, 60/55 but bcos mdyo yellowish sya kaya mas effective on rainy nyts and higher visibility para sa driver. i get mine direct from an osram disributor, but marami yan sa mga car acc shops =)
January 29th, 2005 10:00 PM #9
Kung all-weather bulbs na medyo yellowish, Osram na. Subok ito sa tibay plus some vehicles are sold from factories with that brand in its housing.
Raybrig pamorma lang yan, sakto mapupundi yung bulb pag wala na sa uso para bumili ka ng nasa uso ulit.
January 30th, 2005 01:08 AM #10
what about yung osram silverstar? nabasa ko sa mga reviews it puts out 75m of light sa kalye, tapos kaya daw tumagal ng parang stock bulbs. matagal daw bago mapundi.
Had my 2014 Altis repaired by Tireman PH in Gen. Trias, Cavite last Wednesday. Nawala na yun...
rack and pinion repair
