Results 1 to 10 of 10
    Sep 2006
    Hi fellow tsikoteers! I need your advise....
    Had an oil change in my 4D56 engine.
    Changed oil w/ Valvoline All Fleet 15W40 oil, and changed oil filter with VIC- C306.
    I noticed ..na matagal mawala ang ilaw ng oil warning light after engine starts.. mga 6 seconds delay.
    This did'nt happened before I changed the oil and filter, the light goes off agad pag andar ng makina.
    Is this just normal (6seconds delayed off), or is this something to do with the oil filter? I discounted the possibility of the motor oil coz ive been using this in the past.
    Thanks in advance!
  2. #2
    pagkapalit lang ba ganyan, or ganyan parin hangang ngayon?
    pag-bagong drain/palit, normal lang yung 6-sec delay. pero kung matagal-tagal na at nakailang ikot ka na, check your oil pump...
    Nov 2003
    your oil level may be a bit low. check it again in the morning before startup.
    Sep 2006
    Oil level is ok.
    Delayed response of the oil warning light is only experienced when I start engine after about an hour stop. once the light's gone, stop the engine and restart again, off agad and ilaw. Pag tumatakbo naman at mainit na makina, hindi nama umiilaw ang warning light. Is this bec. of the oil? I used 15W40 Valvoline.
    For as long as the warning light turns off without so much delay,- I think that it is okay.
    2501:showoff:
    Nov 2003
    minsan viscosity has a role... have you used that exact same oil since before? you might wanna change it again...
Oil Warning Light Delayed Response
