which will you prefer, blue vision headlamps or the all weather headlamps? which do you think will give you a brighter or better vision at night in city streets?
BlueVision bulbs emit white light which is close to useless in heavy rains and fog. Stick to all weather na lang for all kinds of driving conditions.
Try Philips VisionPlus or Osram Silverstars, they have longer and wider light throw. Giving you a better view of the road and surroundings.
im also considering changing my headlight bulbs... is 130w/80w bulb(WURTH) a good choice?... can i just plug it in knowing it has higher wattage or will i put a relay with it?.
Since you will be using higher wattage bulbs, better if you put a relay and wiring kit plus ceramic bulb sockets.Originally Posted by cyrusblutrooper
Xt7, mukhang naging salawahan ka sa pagpili ng ng all-weather / season pagdating sa wattage. maninibago ka talaga kung ikukumpara sa stock. pero makikita mo epekto pag napasabak ka sa ulan or fog. tagos tagos ang buga niyan.
IMO bale wala rin ang sobrang taas ng wattage kung marumi or malabo ang iyong lens / reflector or mali o wala sa tama ang alignment ng reflector. kahit stock kung nasa tama sigurado maganda epekto - tipid pa sa kuryente - di hirap ang alternator at mas tatagal ang battery....
kahit stock wattage lang rin pero naka tutok naman sa kasalubong eh wala ka ring makikita dahil imbes na sa kalye at paligid siya tumama eh sa mga mukha at puno ito nakatanglaw![]()
check mo rin maige ang aiming ng. punta ka sa patag at madilim na lugar tsaka mo i-adjust. ingat ka lang baka ka ma carjack. j/l![]()
simple question since baka bukas na ako papagawa. whats good for my trooper? papalitan ko na HID ko sawa na ako, AWB sa headlight or philips extreme bulb? btw yellow hella commet 450 na fogs ko. TIA![]()
Philips Extreme nalang siguro.. kasi kung naka focus naman talaga sa road yung fogs mo eh walang problema kahit medyo puti yung nasa headlights mo.
napansin ko sa photobucket mo yung HID ng Trooper mo.. sobrang lutang yung ilaw (parang sobrang taas at ang dilim).. pareho nung hi beam ng Explorer ko..
post pics naman kapag fogs lang naka bukas.. yung fogs pala ng Trooper ko ang taas din..
oo nga, medyo hirap yung alternator. kapag naka on headlight ko na ngayon na 100/90 W ay nasa positive 20plus yung charging ng alternator( nagpakabit ako ng ammeter gauge) kaya yun parang dapat 60/55W na lang ulit para di masyado hirap alternator.. hehe. excited masyado e.
sa aiming naman ay ok na. na aim ko na ng maayos. wala ng nag fa flash sa akin kapag may kasalubong sa gabi kapag naka low beam lang. naalala ko tuloy dati ng kakakabit lang e nag rereklamo ako bakit ang hina, un pala di naka aim maayos. 1st time kabit low beam lang flash sila ng flash mga kasalubong tapos pag high beam ko, abot langit.. hay... bobo.. buti at nakapag basa basa dito sa tsikot. ayun ayos na.. malakas nga sa ulan, tumatagos nga di gaya ng dati namin ordinary halogen lang.
parang balak ko na nga rin bumili ng tig 400 pesos ba yun na osram nightbreaker 60/55W sa may recto b un? warren auto ba yung sabi niyo sa ibang thread?...
sa ngayon maulan, kailangan muna tong all weathers kaso nga lang mataas humigop ng kuryente... hehe...
Blue vision are cool (aka HID look nga) pero talagang parang imaginary na lang na may ilaw ka pag naulan at malakas pa buhos.
Plus, sa gabi lang maganda yang blue vision na yan, sa araw pag mapalingon tao sa car mo unang makikita is ung headlight kulay blue. May ibang mapapawow, pero may iba namang mapapa-boo, kasi kung di bagay sa headlight at body ng kotse mo ang blue, ang baduy IMO. hehe...
Check out Narva All-Weathers... around 700 for a pair. Good light throw even with tints on the windshield
what's the wattage of the narva bulbs? what color does it emit? do i need newrelays and wiring harness or is it ok with oem harnesses.Originally Posted by ILuvDetailing
Originally Posted by raquino
check your manual bro for recommended wattage. kapag tumaas dun, you might need a wiring kit and relays...
mga bro.. ask lang ni gf kung anong HiD like bulb(ex. Philips diamond vision and etc) ang babagay sa ganitong parklight bulb color?? ayaw nya kc HiD expensive maxado..
narva all weather? wala pa yata two weeks sa akin napundi na agad yun low beam.. and hindi ganu maganda color nya, i've been seeing kasi headlights na naka all weahter, na rainbow talaga yun color, yellow, greenish na may blue.. what brand kaya gamit ng mga yun? osram all weather kaya yun? basta ganda ng kulay eh
san ba makabili ng Philips VisionPlus or Osram Silverstars? tnx!
Consult the specialist:
www.danielsternlighting.com
Buy yellow ones, don't go with the whites and blues:
The blue bulb controversy
Installing relays is an advantage:
Relays: WHY AND HOW TO UPGRADE YOUR HEADLAMP CIRCUIT
Hope that helps.
anyone have tried Bosch all weather? kasing presyo sya ng osram all weather same wattage, wala kasi talaga ako mahanap ng Osram. maganda kaya bosch na bulbs?
