Good day sirs. Can you suggest a good brand of all weather headlight bulbs. Stock watts only sirs. Tia
All weather bulbs are simply bulbs with golden yellow light. Color temperature of around 3000K (Kelvin). Most popular are Osram and Philips. But you can try other brands also. Just check the color temperature on the box. Actually, ang gamit ko for all weather is Philips XV.
Color temperatures:
Osram Fog Breaker = 2600K
Phiips Weather Vision = 2900K
Bosch All Weather Plus = 2900K
Osram All Season = 3200K
Philips X-treme Vision = 3350K
i use Bosch all weather plus
make sure you install relay if you choose the 100w
^ idagdag na rin yung risk na nasusunog din yung connector kapag hindi pinalitan ng ceramic type.
Void po ba ang warranty ng electronic, pag na pundi ang head light. Then pinalitan ng iba na same watts iba lang brand?
Ot lang po,
Hindi. Baka di pa nga alam ng technician sa casa kung anong brand at wattage ng original lamp na nakakabit.Void po ba ang warranty ng electronic, pag na pundi ang head light. Then pinalitan ng iba na same watts iba lang brand?
Ot lang po,
Dewitt All weather (Osram All season similarity) and Xenon Vision Yellow (Polarg Similarity)
i dont think you will be apprehended. the TEs dont know the difference. just ensure road courtesy kung may kasalubong ka and don't put it on beam.
ang kaaway mo sa higher wattage bulbs is natutunaw ang reflectors and nangingitim yung lamps. not to mention it consumes more energy.
