Results 1 to 6 of 6
    Oct 2008
    Ask lang po bakit ang lakas kumain ng energy ang fog lamp ko na customized sa pick up ko. mga 10 agad bawas sa volt meter ko pag nag on po. Paanu ko po ba mababawasan ang kain ng energy ng fog lamp ko?
    Feb 2009
    Quote Originally Posted by robz02 View Post
    you simply can not change the appetite of your foglights. what you can change is your battery size to accommodate this additional electrical load and an upgrade of your charging system to match your upgraded battery size
    Oct 2008
    You mean na magpalit ng alternator? kasi alternator ko my sira na rin, isang root lang ang gumagana. diba normal sa voltmeter ay 14.00, pag nag on me ng fog lamp nagiging 13.00, masmalakas pa sa pag nag on ng head light.
    Baka may problem ilaw or wiring ng ilaw mo. Ilan ba fogs mo? I run a pair on my vehicle and maintained naman ang 13.4V kahit naka on ang foglamps, headlamps, aircon, stereo, etc.
    Oct 2008
    1 set of fog lamp lang po. pag nag on me ng aircon,stereo,headlight = 12.2V agad. and dagdag ng alternator ay by 2 lang. hindi ko lam kung alternator ang sira e.pero sabi ng mechanic ay gumagana pa naman daw kahit 1 root lang.
    Feb 2009
    hard to decipher your barok taglish/englog. if your alternator is broken, it simply is broken and can not give you the desired output. try replacing the alternator first
Ask lang po sa foglamp na bakit ang lakas kumain ng energy ng battery.
