Page 1 of 4 1234 LastLast
Results 1 to 20 of 63
    Oct 2004
    hello guys,
    is there a way to "tint" the headlights/tail lights a bit like the Outlander? looks really nice.
    thanks
    yes. Use an oven. I did it on two WRXs
    After:
    Before:
    Kapatid, kung interesado ka I still have and maybe you can still find a detailed instructions sa iNet.
    pre-heat oven to 350deg fahrenheit
    ganito, gusto mo? :hihihi:
    Oct 2004
    cool can you give me a brief rundown of the process? won't it crack or be brittle?
    thanks..... I love that look.
    Not the second post tho... that's too dark. I want the one used on the Evo 8 mrs lang po
    not mitsu but the painting process is the same.
    http://www.clubwrx.net/forums/archiv...p/t-14169.html
    Had it done in 2003 and no leaks as of yet. No cracks and or brittle.
    Oct 2004
    ****... that really looks nice...
    http://tishandtighe.20m.com/wrx/stg1_hl.jpg
    but could I just pay someone to do it for me? hahahahaha....
    I noticed my Pajero Io has a tinted headlight... complete with the dark metal surfaces
    Oct 2004
    oh man... now that I know this is possible... this will be my project in the near future
    bad driver, make sure your headlight has an inner piece like the ones pictured. If not, you have no surface to paint but the actual reflector:
    http://www.clubwrx.net/forums/showthread.php?t=14169
    Oct 2004
    I have a lot of surface to paint
    I have a Gen3 paj. btw, shoudn't I disassemble it first before baking? so I don't have to bake everything unecessarily? I only need to bake the outer shell to have the desired effect right?
    lastly, I should bake it twice right? two 20 minute sessions for each light?
    Don't worry peeps, I'll try to read more on this hehe.... wish me luck. I hope the Mitsu headlights are made of the same plastics as the Subarus!
    Oct 2004
    hmmm.... I only have an electric oven. would it be the same?
    I'm not sure if it goes all the way to 350 or so farenheit? I think 250 lang ata.
    Might have to go to a friend's house to do my baking.
    Any local Pinoy's tried this yet?
    Disassemble bulbs and wires.
    Kahit electric oven pwede and 20-min baking for each light to melt the sealant. another 20-min after painting to put it back together.
    Saka tama ka, 250deg fah lang ang temp.
    Kung meron ka sanang mabibiling surplus na gen3 headlight just to be on the safe side.
    Oct 2004
    Hehe.... I will read all the posts regarding this befor I even think of doing this
    Malabo atang makakuha ng gen3 surplus lights.
    thanks for the info, Karding!
    Make sure you are quick when separating the headlight assembly.
    nga pala, 15-mins ko lang nilagay sa oven yung headlight ko. Mainit yan paglabas kaya it is best to have a friend help you.
    Aug 2003
    hmmm instead of the oven you can also try the heat gun (much faster) or a blow dryer (which will take some time)
    http://www.pbase.com/paintedheadlight/image/29143569
    BEWARE! not all head lamps are glass some are plastic which can melt easily....can cause u some big moolahs!!! :D
    Quote Originally Posted by Jeepcruizerph
    In case you missed it, we we both have plastic headlights and didnt F'd up mine.
    Yes, you can use the heatgun as well.
    bad driver, keep an eye on the oven. Try to separate the headlights after 10mins in the oven. If the sealant is still hard, put it back another 5mins.
    Trust me, it wasnt that hard to do.
    same lang ba yan ng smoked headlamps?
    kung wala kang heat gun or ayaw mong mag risk sa oven...ito naman ang alternative mong gamit...masakit lang sa kamay he he at nakakapagod...
    http://www.pbase.com/chieffy/image/15747444
    headlights lang ng civic EK ang nabuksan ko...ayaw ko nang sumubok ng iba
    http://www.pbase.com/chieffy/image/17133093
    Feb 2005
    Quote Originally Posted by chieffy
    Chieffy,
    Ilang oras mo ginawa at magkano inabot? Balak ko kasing gawin or...
    ipagawa ko na lang kaya sa yo.
    Aug 2004
    parang ang hirap i DIY yang smoked headlyt ah.
    dpat pla nag HRIM ako ahehehe
    bro,
    look for felix "kalbo" sa banawe, sa may syltech siya tumatambay, he does that service for 1500 petot (dunno kung depende sa kotse) ginawa niya yung sa EK na friend ko, ok pa rin hanggang ngayon..no tuklaps or leaks..may sumunod samin, altis naman pinagawa..
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
tinted headlights
