Results 1 to 6 of 6
    Sep 2006
    master need your expertise on this.. im going to replace the headlight of my Honda Civic Esi 93... anong brand ang the best na ikabit.? and san maganda bumili.
    i want the white one....
    which is better the white or the blue one..medjo malabo na kasi mata ko
    Thank you
    Quote Originally Posted by bat2sai View Post
    Super white?
    White na lang para sa malabong mga mata.
    go for yellow.
    you'll regret the white or blue once you're in a downpour and with an asphalt road...the light won't be able to penetrate as much as the regular/yellow lights.
    all weather or yellow since malabo mata mo.
    next time, please use the search function. there have been scores of headlight threads/discussions already in the past.
    Jan 2004
    yep. all-weather yellow is good. or, if you want, get an IPF 70/80W or 90/110W lamps- these won't a relay. but go higher than 90/110W you'll need one. anyways, have your headlight lenses cleaned too. para talagang maliwanag- saka kung buo ang tint nang windshield mo, pa-tanggal mo na yung 70% tira ka lang nang mga 7" sa upper portion.
    You might need to have the socket replaced to "ceramic" types, if you plan to get high powered version.
Please help...im going to replace my headlight
