Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Jan 2008
    sir in terms of visibility and style alin mas maganda yellow HID lights or un white? tnx
    I have both on the same vehicle.
    Depende sa daan. Pag concreto, puti. Pag asphalt, dilaw.
    Jun 2007
    halos parehas lang e
    pero mas may edge ang yellow depende sayo yan
    Oct 2007
    kung porma po go for the white one. although yung yellow mas effective sya when it comes to asphalt roads, rain, fog, smoke. pero based on experience tumatagos din naman yung white HiD's sa fog and rain unlike the white halogen lights. yun nga lang mas malinaw talaga ang yellow HiD's. kaso in my opinion yellow HiD's don't really look like HiD's. so it depends sa preferences mo talaga actually. hope this helps.
    Mar 2003
    imho go 6000k sir, up and down. but you cant use your foglites pag may kasalubong pag HID ka, kahit na anong adjust gawin mo super glaring siya.
    Jan 2008
    tnx mga sir,, san kea ako mkahanap ng HId d2 sa paranaque?? un budget meal lang.. newbie pa lang kase ako..
    Quote Originally Posted by jizzle View Post
    Budget meal for HID? Hmm... doesn't make sense. Pero if you're referring to a cheap set, well, although I go for cheap, I don't go for unknown HID's. Personally kasi di kasi ganun kaganda ung buga ng mga unknown brands. Pero kung porma lang, wouldn't hurt. Try searching around the forums. Pero as per dito sa Paranaque, your best bet would be in BF Homes. Good luck!
    May 2007
    Nakakita ako going towards BF Homes, pakalampas lang ng Tahanan Village ata! Its just beside Brooklyn Pizza if am not mistaken... Yung shop na nag dedetailing! Sa totoo lang kase ang HID bulbs most often than not is for show lang, lalu na if your car's not really meant to have one. Minsan kelangan mo pa magpa relay para makayanan ng kotse yung lakas ng wattage. Meron din naman mga HID converter kits just in case you might need one.
    Pero tama yung ibang Tsikoteers, mas maganda bilhin mo yung kilalang brands for HID's! Ako I placed a 6000K HID Bosch for my headlight but not more than that kase walang use sa ulan.... Then for my high beam, yellow 2500K hallogen. Yung sa fog lamps ko pinalitan ko rin ng yellow hallogen bulbs to compensate for the white HID's.
    Jun 2007
    IMO pare pareho lang ang mga HIDs habulin mo nalang sa warranty (tagal) kasi pag branded ang HID mo sure mahal
    Tama si LD maganda halogen yellow bulb kung sa fogs lang lalagay
    Oct 2007
    i agree... magkakaroon ng contrast. yellow bulbs with the white HiD's. besides, meron kang yellow lights which, when needed, would come in handy.
    Jan 2008
    un copperblue pu ba ms. Ld un snsbi mo? o lagpas pa pu dun??
    Jan 2008
    may nkuhang HID ang tito,, 13k.. Z-Max ata ang tatak.. kea nag hahanap ako kung my mas mababa pa dun,,
    May 2007
    Naku jizzle sorry ha di ko alam yung colors pero bluish white yun! 6000k ang lakas ng buga nung HID.... Bosch ang brand and its 8000 a pair... with 1 year warranty.
    Jan 2008
    Quote Originally Posted by LadyRider View Post
    un bosch un ba yun 8000 a pair tas hi&lo na??
    May 2007
    Good day po sir! Low lang po sya kase sa Sta. Fe hiwalay ang bulb sa high at low...
    Oct 2007
    Yellow or white HID's? Functionality, definitely yellow. It would not glare as much the white ones. HID's are for cars designed for HID. IMO, HID's cause glare that can cause accidents if used for cars that are not meant for the HID kits. Better think about it before getting one. I for one once opted for HID's na budget meal. Sinubukan ko lang. Glare galore. Daming kaaway na sasakyan, daming haters at kung ano ano pa. Kung gusto mo ng puti, go for the higher wattage halogens. Pa relay ka nalang and ceramic sockets tpos 100w/90w na bulbs. Functionaltiy is better than looks.
    Just my 2 cents.
    Sep 2005
    I haven't yet encountered a vehicle using yellow HID(hid kit w/ ballast). Nakaka decieve kasi yung lakas ng yellow color. I went to a lotta shops in Banawe asking for that and ang sabi nila lahat ay yellow halogen bulbs lang yun na mataas ang watts. Kasi when I check yung kelvin color it's from white to deep blue. The higher the kelvin the darker the color. I also want to use a yellow HID kit para di masyado hirap ang battery and alternator ko since 35W lang ang consumption ng power nito compared to halogen na 55W pataas.
    May 2008
    ok yun hid 3000k.malakas at malinaw kaya nga lang pagnakasalubong mo yun oto na nakayellow hid sa unang tingin parang di hid pero pagtinginan mo yun sinag sa kalsada malakas.di tulad ng superwhite talagang malayo palang hid na talaga ang dating.
    May 2007
    Quote Originally Posted by SaberRider View Post
    Hello po Sir! For my Hyundai Sta. Fe and Veracruz fog lamps, I had it changed to a 3000K Yellow HID. Maganda sya lalu na sa hi-way. Yung Stock kase ng SF at VC ay hallogen lang. Mas lumiwanang nung pinalitan ko ng HID na yellow.
    Kahapon nga nung nanggaling kami sa Outreach sa Tagaytay, nagamit ko yung headlight saka fog lamps na HID ng Sta. Fe ko sa SLEX kase umulan ng malakas!
    Maliwanag pag pinagsama mo ang HID na yellow saka white kase kung white lang, parang wala kang ilaw sa ulan. The yellow HID balances the light that is emitted by your car... Just my two cents po! Saka subok ko na po...
    sakin 8k low beam white halogen sa high then yellow halogen sa fogs ..
much better HID na yellow or white?
