Results 1 to 3 of 3
June 13th, 2010 10:46 PM #1
Need advice on HID, sometimes when I turn on the head lamp of my CRV 99 model walang ilaw ang driver side then after several minutes when I turn it off and on again babalik uli ang ilaw. Hindi naman ito nawawala once umilaw na. Mostly nangyayari lang ito whenever bubuksan na ang headlamps. Hindi ko ito pansin when I push the "Pass" signal kung meron or wala. Maraming beses ko na ito na experienced. Saan po ba ang problema ng ganitong sitwasyon ballast or bulb po ba? Hindi ko pa ito na papacheck-up sa Mechanic/Electrician. Ang pinaka worst na experienced ko is recently nung akoy pauwi from alabang area going to laguna at around 8pm. Pag on ko ng head lamp wala yung left lamp I tried pushing the high beam and low beam biglang nawala din yung lamp ng right side. Parehong wala na kong head light. No choice binabay ko ang SLEX with hazard mode ang only park light. Takbong pasyal mode 60-70kph. Sa bandang Carmona area biglang umilaw ang right side napa Thanks God ako. Up to bahay wala pa din yung kaliwang lamp then on ang off lang ako ng head light biglang umilaw naman ang kaliwa so both lamps na ang may ilaw. Ano po kaya ang problema ng ganito?
Please help. Thanks
- Jun 2010
- 47
June 15th, 2010 10:22 PM #3Sir, madali lang yan ang probelima mo/ito check mo ang main fusi box h/l linis ng fusi at mga connector sa head light/ head light relay connector,kahit ikaw kaya mo gawin yan,
Ongoing problem pa din Pala ito even among euro cars ...
Takata Airbag Problems
