Results 1 to 20 of 21
    Feb 2012
    Need help tsikoteers
    just installed my 55w 4300k
    How true that i cannot use my hid as flasher when turned off? Need inputs on hid users. TIA ;)
  2. #2
    you have this on your stock halogen headlights?
    Quote Originally Posted by rap2_tan View Post
    I think the reason HIDs cannot be used a flasher is because the system needs time to "warm-up" to operating brightness.
    Feb 2012
    Sir gary, yes dont yet have the budget on projectors ;)
    Masisira ba hid if i use it as flasher?
    im also wondering during warm up the left hid is whiter than the right side
    After warm up nagpapantay naman sila... Is this normal?
    Mga sirs any tips, do's and dont's sa hid? TIA ;)
  5. #5
    Bro I am not asking for you to get a retrofit ok? I know people need better lighting perfomance for their cars and that is normal but we have to consider how our upgrades can affect other motorists. Using pnp hid kits on stock halogen hl will cause so much glare to other motorists much more if you are running on 50w. Caveat din, this might ruin your chrome reflectors. I hope you consider these points.
    To comment on your questions:
    yes mas madali masira pag lagi fina-flash, especially cheap kits
    cheap bulbs usually dont match in color.
    Ikaw yung nagtanong dati about plug-and-play HID kits 'no?
    You were informed by several forumers about how plug-and-play HID kits can be blinding to oncoming motorists, even when simply used as low-beam lights. This is regardless of what the color temperature of the HID. Mapa-4300K, 6000K, o 8000K yan, kung mumurahing HID yan na sinalpak lang sa housing ng halogen reflector headlamps, nakakaperwisyo yan sa oncoming motorists.
    Nasa 1,200 lang ang Osram Nightbreaker. Mas malawak pa yung illuminated area with those bulbs than your HID. Maliwanag nga yang sayo, sabog naman.
    I've read about this too. I have to ask though, what about bi-xenon headlamps where both the low and high beam bulbs are HID?
    Buti pa dito sa tsikot panay ang paalala sa perwisyo ng hid na walang projector. Sa iba kasi ang payo pa wag lagyan ng projector kasi nababawasan daw liwanag.
    ^ Alam ko rin kung saan yan... :lol:
    Sa Tsikot kasi, if you can't avail of good projectors but in need of improved lighting, there's the plug and play halogen bulbs. Osram Nightbreakers, Wuerth, Philips XV/XP
    Pero kung gusto mo talaga mag-HID, dun ka na sa projectors talaga. It may not be of gary's, basta projectors para clear cut off.
    *BratPAQ, renz, marion2
    Mukhang nagkakaintindihan tayo dito. Hehehe.
    Amen!
    To the TS sir rap2_tan, I posted a reply sa thread sa kabila, page 2 yon at ni-revive ko pa ang thread for the sake of HID newbies, I explained to them to the best of my ability and base din sa nababasa ko sa thread ni sir garyq (matagal na akong lurker sa thread ni sir gary at matagal na ring naglaway). :D And pansin mo sir may kumontra, but again I explained it further to the said forumer. Pero wala naman na ako magagawa kung ayaw nya or ng mga tao roon na maniwala sa sinasabi ko.
    Sir, frankly if you want honest opinions, tsikot has it. Wala kami dito para i-sales talk ka, or recommend ng recommend ng kung ano ano tapos di naman makakabuti sayo, kitang kita naman sa comments ng mga forumers po natin dito. Nandito kami to give you honest opinions, minsan may mga nasasaktan sa mga comment ng tao dito kasi they can't accept the truth or ayaw nilang naccriticize. Ang masasabi ko lang, nagtanong pa sila. :p
    Tsaka btw, ang purpose po ng headlights natin is to give us light on the ROAD where we need it most. Hindi po sukatan ng liwanag ng ilaw natin kung naiilawan na pati bintana ng 2nd floor ng kapitbahay natin. Put that kind of output on the road and you'll be blinding oncoming motorists. HTH sir. Just being honest here.
    Hehehehe. ;)
    Amen.
    Dito kasi sa Tsikot, ang gusto lang namin ay masulit ang pera. People here just want to give the best advice they can for the betterment of the person asking. Maaring yung iba dito magalit because most of us are actually against plug-and-play HIDs pero keep in mind na hindi naman namin ginusto na mag-look down sa binili niyong bagay. If you insist na gusto mo ng plug-n-play HIDs, then so be it. Basta sa'min, nasabi na namin yung mga pangit about that certain product. Natural lang na gawin namin yun kasi naiinis na kami sa mga taong sobrang sabog ng HID kahit naka-lo beam na.
    But then, to each his own. Kung gusto mo pa rin. Ok, sige lang.
    Anyway, OT nanaman.
    Re: topic, yes using your HIDs as flasher can shorten its lifespan. Kung H4 yung headlights mo, sana yung binili mo ay HID lo, Halogen HI para pwede mo siya gamitin as flasher. But then, yung HI, ganun nalang purpose niya -- as flasher. Kasi sobrang useless niya na if you tend to use it at night. Some even say that using a flashlight would be more helpful than using your HI Halogen from your hidbulb during sun down. I guess, applicable yun sa very cheap HIDs (4k below?)
    Nov 2012
    Newbie question po regarding HID....hirap kasi magback-read sa sobrang daming babasahin.
    I have a 2013 montero sport gls-v a/t. if i choose to change my head light to HID pwede bang palit lang ng bulb? looking for more info and recommendation. Tnx.
    Quote Originally Posted by jhunc08 View Post
    Monteros have projectors, but the projectors are designed for halogen bulbs. Hence, it will do great when fitted with halogen bulbs but would do okay (take note: I said okay, not bad) when fitted with HIDs. It's fine if you're on a tight budget, the projectors would still give a cutoff putting the oncoming motorists at a safe "place" but with halogen projectors, you are not able to maximize the HID's output because it's placed on a "container" that's not for it. Place it on a HID projector, then you can say that "night is the new day" ;)
    Then again, if you're on a budget, or would just like to put the rest of your money on more practical stuff, it's okay to use your stock projectors. At least you have projectors, unlike others...
    O kaya kung makakahanap ka ng OEM reflector housing na designed for HID. Tipong naka-Altis 1.6G ka tapos palitan mo ng housing ng 2.0V para pwede ka maglagay ng D2S HID kahit hindi ka naka-projector. Pwede rin 'to with the 1.8 FD Civics upgrading to 2.0S headlamps.
    Ewan ko lang kung magkano yung ganyan, baka mas mahal pa kaysa kay sir gary haha.
    Jan 2011
    Madami kase masyadong bihasa dun sa kabila kaya nakakatamad na dun
  15. #15
    Been around since the start of auto forums, you can see here since 2002 pa, hehe so that will give you a clue on my age.
    Important naman we act with decency and respect for everyone. Yung mga forums na tumagal, yan yung open for all pero meron self moderation ang mga members at respeto sa isat-isa. Isa pang important lesson for me, pag meron problem, you can solve it outside the forum na mahinahon, no use washing dirty linens in public.
    OT na, hehe. Going back to the issue in hand, yes as mentioned pwede to get HL na hid reflectors pero only if it's offered sa vehicle mo like the Civic 2.0, Forester, Altis 2.0, etc. Pag nakahanap ka ng surplus pwede yan but kung JDM makuha mo then baliktad yung step so hindi rin pwede. Fyi lang, I think mga 2x improvement ganitong setup pero less pa rin sa performance ng good qulality HID projector.
    Mabuhay ang tsikot!
    Haha, la naman tagadoon na nagbobrowse dito ha? May nakaaway na kong mga om dun eh, hehe. Sssshhh!
    Problem kasi pag may kasalubong na hid na sabog, i cant see their vehicle all i can see is their headlight, also pag may tumawid sa harap ko di ko nakikita dahil silaw na nga.
    For me its selfishness na mas nakakita ka nga kasalubong mo naman ang hindi makakita.
    May point naman ang nagsasabing mas maliwanag ang multi reflector vs projector. (Di ko alam kung saan yang 'kabila' na tinutukoy niyo though.) He probably has had the same misfortune as myself and he stumbled on crappy bolt-on or halogen projectors. Kung yon ang basis niya, I would tend to agree with him.
    Pero, wag naman niya lahatin ang projectors. Ang pwede niyang i-generalize, is that multi-reflectors bring out more glare than projectors -- the best or the crappiest projectors at that.
    ^Pwede sir but the output won't be as good as compared to projectors designed for HID.
    Btw 2 pages lang ang thread. It's just 5 minutes to backread yet we kind of summarized it already hehe.
    Thanks po for the info *Chikselog and *renzo_d10. Still not decided if going to change to HID....since bago pa si Montero ok naman yung stock headlight for now. Worried about changing to HID if would affect the warranty.
    Another option to consider is to change to a better halogen bulb...any recommendation po? Again thank you.
    Sir. Basa basa ka lang dito sa tsikot. Pati halogen bulbs nadiscuss na.
Hid newbie
