Results 1 to 12 of 12
    Pinabuksan ko headlight ko kasi pumutok ung isang bumbilya at lahat ng bubog nun e nasa loob ng headlight. So, no choice kung ndi buksan ung headlight. Ngayon naibalik na kaso ang prob ay nagkakaron na ng fog ung loob ng headlight..
    Fellow tsikoters, baka me alam kayong paraan para matanggal ang fog na to or me alam kayo na magaling mag ayos ng ganitong prob.
    Salamat
    Baka mali ang kabit mo nung rubber grommet (the rubber round thing). Nag-fog din kasi ilaw ko nung inayos ko bulb. Minsan baligtad or tagilid yung kabit ng grommet. Minsan mali ang order (grommet muna before socket).
    In my case, kulang pala sa diin. I had to run my hand around the grommet and diniinan ko every step of the way.
    Ang hassle lang diyan ay ang pagtanggal nung moisture. I forgot how I did it. Hair dryer yata.
    pakabitan mo ng FOGLIGHT sa loob ng headlight. hahahaha :bwahaha: dyok!
    sa pag re-seal lang yan...baka di maganda pag balik.
    try mo si felix kalbo ng syltech sa banawe. ;)
    hair dryer sana suggest ko to temporarily remove the fog like what otep said, baka maluwag goma or di masyado adapt kaya nag fog
    just turn on the light. the heat will dry the inside of the lamp.
    Malamang sealing nga ang mali, kung hindi mo pa rin maalis, try silicon grease sa rubber fitting nya to help seal the assembly...hindi naman didikit yung silicon grease so pede mo pa ring alisin in the future. Ako pinupunasan ko lang ng maigi (tissue) yung lens before I re-seal it.
    Mar 2005
    Quote Originally Posted by baiskee
    Sir Baskee, where can we find Syltech?
    TIA po...
    Yup saan Syltech bro? Can they also clean the headlights and seal it pati yung reflector sa loob?
    Big Bert's also offers headlight cleaning.
    Quote Originally Posted by OTEP
    Sir from what ive read naka alis na ata headlights bago mo dalin sa kanila?
    Ganun din sakit nung akin after I had my angel eyes done. Malipis na kasi yun rubber so nilagyan na lang nila ng sealant. ngayon ok na sya.
    Jan 2004
    yup, Big Berts offers Headlight cleaning provided you bring the headlights.
    sealant ang problema dyan. seal mo na lang. naganyan din ang Dmax namin when it is fairly new, mga 6 months old. pero ngayon ok na ulit.
Need help: Fog inside the headlight
