Page 1 of 3 123 LastLast
Results 1 to 20 of 231
  1. #1
    Upgrading to HID requires some things to be considered, its not just placing the hid bulb inside your headlights and expect everything to work fine.
    HID and HALOGEN are two different technology, they differ in the way they emit lights.
    Optic engineers designs the headlight of a particular car with the light source as the primary basis. if they are designing for HALOGEN headlights, they use a HALOGEN bulb as the pattern. Same goes for HID, in designing HID headlights, they use HID bulb as their pattern and reference.
    Now when you place a HID bulb inside your HALOGEN designed housing, that's when things go wrong.. terribly wrong.. Your cut off will vanish, lights are just scattered everywhere without direction, practically useless, and will not pass any safety regulations, you become a hazard to the road, you spent something that is practically useless as far as USABLE LIGHT is concerned.
    by standard, any automotive headlamp light projection should have a beam pattern.. these is what we call CUT OFF, its the vertical lines you see on halogen light projections
    just like this picture below.
    ** notice the step pattern, the step is towards the right side because we are driving in a left hand drive country. This step pattern gives additional light towards the passenger side which is NOT directed towards the opposing traffic and thus deemed FUNCTIONAL USABLE LIGHT.
    now by upgrading to HID without doing anything to your headlamps which accepts HALOGEN originally.
    what you get is GLARE.
    these is what blinds other motorist on opposing traffic, much like driving with your high beams always on, now that's just not polite. Have you ever flashed somebody cause their lights is on high beam? or better yet have YOU been flashed at because you forgot to switch your lights back to low beam? kinda embarrassing isn't it?
    now we have established that its a NO NO to put plug and play HIDs to our HALOGEN headlamps..
    but we are insistent....
    we want to have HID too like they have in luxury cars...
    we want to have brighter lights at light....
    we want to have that cool BLUE effect on our lights...
    but all we know is to plug 8000k colored China HIDS in our headlamps..
    but there is a solution.. and it is called HID RETROFITTING..
    HID RETROFITTING can be done by two ways, retrofit a reflector that is designed for HID (commonly uses D2R base bulbs) or retrofit a projector that is designed for HID (commonly uses D2S base bulbs).
    The latter mentioned is the most common way.
    by retrofitting a HID Projector in your existing headlamp housing, what you get is a razor sharp cut off, even light spread, better light efficiency, intense beam output, wider beam coverage, and of course a CUT OFF line.
    some aspects may vary base on design of the HID projectors.
    driving a car with retrofitted hid projectors compared to plug and play is like NIGHT and DAY. you can clearly see that nice cut off line when your driving.. unlike when driving with a plug and play HID, light is scattered all around, imagine, all the UNUSED light everywhere, but when in a projector, all the light is concentrated where it should be... BELOW the cut off line.
    Now lets talk about bulb colors.
    We know that when we hear HID here and there, we think that the color should be white , blue or even violet!
    We can thank our friends in CHINA for manufacturing such bulb colors for automotive use..
    OEM HIDs uses a color temperature of 3900k - 4300k which is expressed as yellowish white in our terms here.
    OK now some may wonder... why are some AUDI's, BENZ, BMW's, LEXUS, CAMRY's, 300C, have a blue colored lights when they were passed by that car??
    if OEM color is yellowish white, why are they colored blue from afar?
    Now here is the answer that you have been awaiting for a long time ago.. the answer is DIFFRACTION of light.
    HID projectors have a cut off shield, this is a metal plate that is placed strategically in between the Ellipsoidal Reflector and the Plano-Convex Lens. Light passes thru the shield and is diffracted because of the sharp edge, these breaks light into many colors. these is what we call as the COLOR BAND.
    notice in the picture below
    that color band is what you see from afar, its called COLOR FLICKER.
    a car with a color band like that will have COLOR FLICKER's when viewed from afar, colors would range from blue, violet, cyan, magenta, orange. now that is nice!!
    now lets get back to our AFTERMARKET MANUFACTURERS..
    they want to replicate that color flicker as seen from the high end cars with hid projectors so they produce a blue color bulb. (color temps 6000k up to 12000k) LOL! :lol:
    okay, they replicated it already, admittedly..... a car equiped with a 6000k or 8000k looks COOL!
    very unique from the rest of the pack.
    now heres some concrete hard facts for you..
    lets compare bulb ratings
    color range Lumens (which is the amount of light intensity)
    Halogen 900 lm ~ 1600 lm
    4300k 3200 lm
    6000k 2400 lm
    8000k 1700 lm or lower
    10000k forget it! stick to your halogens
    Light intensity is always INVERSELY PROPORTIONAL to Color temperature
    in simple terms
    the higher the color temp the lower the intensity.
    the more blue your bulb is the less light it emits.
    Now lets talk about COLOR SHIFTING.
    hid bulbs COLOR shifts as it get old.
    color shifting means that the color will change after the bulb is used for about 200 hours or so.
    so a 4300k color bulb will color shift to 5500k or so when its used.
    same goes for a 6000k, it will shift to about 8000k or so when its old.
    so the same rule still stands.. when the bulb color shifts, it losses light intensity.
  2. #2
    Examples of retrofitted headlights
    pajero fieldmaster
    corolla ae111
    honda jazz
    honda civic
    ford lynx
  3. #3
    honda civic
    corolla altis
  4. #4
    nice clean cut offs!
    low beam
    high beam
    Heres the real HID output!
    very wide output pattern! using only a single bulb! thats true lighting efficiency. just count the number of parking lot lanes it covers!
    well explained there sir. thanks for the infos!
    Mar 2007
    very very informative sir!
    noob question lang po: kelangan pa po ba hid retrofitting sa montero? if yes, how?
    Jun 2010
    Quote Originally Posted by NighthawkGT View Post
    low beam
    high beam
    Hi Sir, very informative thread you have. I am planning to have my headlight changed to a retroffited hid like the ones posted in this thread. I was wondering how much it would cost me to have my lights changed? I have a 98 Civic. Also, where is you shop located? Thanks!
  8. #8
    kindly check your inbox bro
    sir nighthawk... kotse ko po mistu lancer 98... kapapa install ko pa lang ng HID... pede po pa iparetrofit ito? gumagawa po ba kayo? after reading your thread, gusto ko iapgawa ung kotse ko for retrofitting to maximize yung HID and be safe to other drivers...
    NighthawkGT, a very informative article.. can you send me a quatation for tucson 2010 low beam headlights only. my cel 09177942898.thanks in advance.
    Quote Originally Posted by tonio65 View Post
    NighthawkGT, a very informative article.. can you send me a quatation for tucson 2010 low beam headlights only. my cel xxxxxxxxxxxx.thanks in advance.
    bawal po magpost ng personal info such as cellphone numbers and emails.
  12. #12
    you have pm on this one too. thanks
    Feb 2009
    sir nighthawk,,,
    just want to ask, because i will be buying a new honda city 1.3s. As you know, there is no foglamps included in the 1.3 model. I am planning to have hid foglamps installed in my car. Is this recommended? This will be my first car and Im kind of a noob here so really need your help.. What I mean is, if I install foglamps in my new car, pwede ba yun? Im worried kasi baka sabog yung light or baka hindi maganda yung labas eh... sayang naman po money if ganun lang yun mangyayari... thanks so much!
    Oct 2009
    Quote Originally Posted by wingeofus View Post
    sir nighthawk,,,
    Sayang pera kung pa HID mo foglamps mo, why get some pure yellow halogen bulb for foglights since tag-ulan na rin?
    Feb 2009
    Quote Originally Posted by Battlestar View Post
    d ko po kayo gets sir... what do you mean yellow halogen bulb? Diba ang HID is white light na maliwanag?
    May 2010
    sir nh pa pm naman po quotation nyo for my ride 2006 isuzu xwind.. kahit sa headlights lang po gusto ko talaga mag upgrade ng hid eh.. after reading this thread hindi pala ganun kadali mag palit thanks in advance
    nice thread sir... ako sir may ari ng mitsu 1998.. kakapalit ko pa lang to HID.. san po pwede magparetrofit?
    Quote Originally Posted by trekker16 View Post
    sir ask ko rin if you can do retrofitting sa kotse ko... mitsu lancer 98... gusto ko ma-maximize ung recently added HID ko... and be safe to other drivers..
    Apr 2011
    Hello po, thanks for the very useful info. I'm a real noob at this so I was hoping you could help me. I have a 98 civic and my headlight is really faded (beyond detailing), so the light coming out of it is very dim. Plus, my windshield is fully covered with 3m tint. I forgot the specifics about my tint but I’m sure its not that dark since I can still see clearly at night from the inside of my car.
    Anyway, I would just want to have a brighter light and I’m not sure if I should consider HID. What I’m sure is that I need to replace my headlights. And if that is not enough to satisfy my need for brighter lights, I will be turning my head to HID. So here are my questions:
    1.Where do you recommend I buy or have it installed? I live in Sta. Mesa – not far from banawe. Any particular shops you could recommend?
    2.What’s the current cost to have a retrofitted HID installed in your car?
    3.I heard from a friend that once you install HID, you won’t be able to use your high beam, or flashing your light is a “no no” as it might shorten the life of your HID. Is this true?
    [SIZE=3]TIA[/SIZE]
    [SIZE=3][/SIZE]
    [SIZE=3][/SIZE]
    Sir NH,
    Can you pm me how much it will cost to retrofit my Xtrail with Bi-xenon projectors 4300K. If possible, send me quote for entry level, mid level and high end. I am presently using H4 Hi-lo 4300K and not happy with the result.
    I also sent you same inquiry to your email add.
    Thanks in advance.
Things to know when upgrading to HID
