Results 1 to 6 of 6
    Aug 2003
    gurus,
    pna-check ko yung kalampag ko. sabi daw one of the causes is yung steering bushing. dati pinalitan ko ko ito, plastic yung nilagay. after sometime nasira ulit ito. sabi nila eh mas ok daw machine shop na ito.
    what do you think?
    Thanks
    Nov 2003
    it really depends on the bushing but in some cases you have to send the bushings to the machine shop to have them pressed in/out before installation. baka ganun yung sayo. try to get a 2nd opinion muna tho before you have the work done
    Feb 2004
    If the steering wheel does not feel loose if you bang your hand on it, the kalampag is probably coming from somewhere else. Have you tried checking your shock bushings? You can check these by raising the car on a jack and try to move the shocks with your hand/s.
    Jan 2004
    tama ang mga gurus, but i think you also need to check yung mga tie rods din. saka yung mga rubber bushings sa rear suspension. dati nagkaroon din ako nang ganyang problema. medyo me kamahalan nga lang ang mga parts, kasi lahat pinalitan ng bnew.
    Nov 2003
    easiest solution is still to get a 2nd or even 3rd opinion. that way you can make an informed judgment
    Aug 2003
    Thanks gurus!!! siguro nga dapat mag-2nd and 3rd opinion.
    Thanks again!
94 Lancer Gli kalampag
