Results 1 to 13 of 13
    Feb 2005
    Mga papa, saan kaya makakabili nito? Ang mahal kasi ng benta sa sites. 600php
    Sir sa suki ko sa evangelista 500 per bulb ang singil... halos kasing-presyo lang din pala.
    Feb 2005
    Mahal pa din ah. Considering LED lang naman to. Acceptable eh around 300php.
    Jul 2006
    saang lugar pa kaya puedeng makabili nito?
    May direct-fit [no mods] na bulbs na HID-like ang kulay. Ganun gamit ni kcboy sa loob ng Rexton niya, hindi ko lang natanong where and how much nabili.
    Pero ang advantage niyang nasa first post ay talagang maliwanag siya compared dun sa super white bulb.
    Feb 2005
    Nice input doc. Noted! :D
    That bulb should be a cheaper alternative.
    HID ba o LED...bakit ang intindi ko ay LED?!?
    At P600 halos sulit na, kasi if you DIY that halos pareho lang din price nyan:
    Super bright white LED's are about P20 a piece sa Alexan (found in sm megamall 5th floor, sm north sa computer area under the parking lot sa likod, sm pampanga, elcano st binondo)...perhaps other electronic shop will have it also.
    The picture shows something like 20 LED's in there...so P400 na yun.. the adaptor and some voltage regulator (LED's doesn't need 12v to run... usually about 3 to 6 volts lang) set-up will bring the cost to near P500-550 range (without labor).
    Jul 2006
    Don't forget to clean the plastic lens/cover. Most of the time nangingitim ito't nagdudumi, kaya dumidilim.
    Feb 2005
    Hey, hey.. That made me think sir wild thing.
    BTW, I was referring to hid-like look of dome lamps. Be it because of the LED's or a super white/bright bulb.
    Anyway. maraming salamat. :D
    Sep 2004
    When I DIY'ed my VTEC light project late last year, I bought several superbright LEDS sa Alexan (SM City Fairview). Different colors, and they cost only P8.00 each
    Yung mga flashlight using superbright LED's cost only P200 sa Handyman (and even less sa Divisoria at suking bangketa)
    super bright na white ang mahal...yung red, yellow colored are cheaper than the bright white.
    Sang site yan?
    www.ih8mud.com 's LC80 forums have this LED dome lamp mode in detail. Just use their search function.
HID-ish Dome/Map light
