Results 1 to 17 of 17
    Jul 2004
    I want to replace the headlight bulbs on my Suzuki Esteem to really powerful halogens, not the white or HID types. What's the maximum for replacement bulbs in stock headlamps? I found OSRAM 100 / 180 but are there more powerful choices available? I don't want to go overboard and need to replace my alternator or something just to run the headlights. I just want the brightest lights I can get, best bang for the buck kung baga, and still retain much of the original wiring and setup. I already had my headlamps cleaned at Big Bert's pero kulang pa rin hehehe
    Quote Originally Posted by Bud_wiser
    You'll have to change to ceramic sockets if you use the 100w+ bulbs, also, it might blacken your headlight lenses, you could try the Osram Silverstars or Philips Visionplus instead, it's 55w but has wider and longer light throw.
    Sep 2005
    * falken: how much for one pair bro?
    Quote Originally Posted by jeffishot
    Philips Visionplus H4 P850 at Autosport Megamall or Perfect Circle in Banawe, P1,000 ang Osram Silverstars H4. Mas malayo lang ng kaunti ang light throw ng Osram Silverstars.
    mine is stock 55/60 but i tilted it a bit so ganda ng buga (yung sapul pa rin ang kalye. i put my 55/60 super white during summer and ganda rin ng tapon.
    Sep 2005
    can u recomend a cheap set na ok lang for a '95 corrola? i replaced mine but i forgot kung anong klase but i ended up suffering coz halos walang ilaw. i dont know if there is something wrong with the installation or kung pangit lang talaga yung nabili ko. i already forgot kung anong klase yung binili ko. ur help will be greatly appreciated.
    With the stock wirings and sockets, you can only use the stock bulb wattage specified. If you'll go higher wattage, you'll change wires, add relays and change sockets to ceremic ones (mga 1.3-1.5K at electrical shops like Wizzard and Reys... guaranteed pulido gawa over the cheaper shops in Banawe).
    Avoid those "super whites" and blue bulbs as they don't work well in poor weather at night. Stick to the stock white or all-weather colored bulbs.
    There are several topics on this as well which you can dig up through a search...
    Aug 2005
    Did this, sulit ang upgrade.
    Thanks again vinj sa payo!
    Jul 2004
    I realize that I will have to beef up the wiring and use ceramic sockets. Yes Wizzard is an excellent shop. I've been going there for years and ang galing talaga ng work nila.
    My lenses are glass. Will they still darken if I use more powerful bulbs? And are there bulbs available that are capable of more than 100 watts on low beam?
    If your lenses are glass it won't darken.
    sir vinj: if ever mag change wires, add relays and change sockets to ceremic one to my car 96 corolla it will make it clear na kaya? hindi kaya makakasilaw sa mga kasalubong ko yun? what you think?
    OT, why majority of newly released models use plastic headlight lenses? any opinion?
    super white bulbs are useless when used on wet asphalt roads.
    so ano po best way? don na lang tayo sa original?
    go all weather
    or if you have the moolah, 4300k HID kit :evillaugh
    this is the closest thread i could find relating to my question. i am thinking about replacing the H7 and H1 lamps of my focus from stock to 85 watts. can the stock assembly handle this, or do i need to replace the sockets/wiring/etc? salamat po.
    Jul 2006
    plastic ba ang headlight lens ng ae92?
max bulb power with stock headlights?
