Results 1 to 4 of 4
    I have a problem with my reverse light switch, defective na sya, I already checked my bulbs and my fuse ok naman switch lang talaga ang prob. I also already know where to find the reverse light switch. I just want to be sure kung pwede syang DIY bili na lang ako ng replacement switch then ako na lang magkakabit. Ano po bang kailangang tandaan kapag tatanggalin ang switch?
    salamat po!
    Nov 2003
    just remove it and replace it. no special procedure doing it naman.
    May 2007
    Quote Originally Posted by SpiritBeing View Post
    salamat po!
    Yong switch ay nakakapit (bolted) sa may tranny mo malapit a may tranny linkage. You must remove those plastic cover(console) of your tranny para ma access mo yong switch. Palitan mo kung sira na nga at madaling tandaan ang wiring dahil most likely one way ang pasok niyan. Easy to change, kayang kaya mo yan.
    thanks mga bro, nasubukan ko na kaso sobrang higpit ng kapit nung switch tapos marami pang sagabal para maikot yung bolt, try ko ulit using wd40 baka makuha ko na =)
Reverse light switch
