Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    WHat do you recommend - best visibility h4?
    On stock wirings, Philips Vision Plus is okay...
    If you want more wattage then upgrade the wirings, sockets and relays so you can use a high wattage bulb (i.e. 90/100W).
    Been using Philips Vision Plus. Malakas buga.
    Sep 2005
    OT: mga sir, baka meron kayong DIY HID replacement? di ko kasi alam kung paano tanggalin yung stock, balak ko bumili either Philip Vision Plus or Osram All Weather. tia
    Quote Originally Posted by typhoon View Post
    Definitely agree... walang kuwenta ang 100/90... and all weather pa ito. Pricey ng lang ito. Sa Blade Php 899.75 ito pero sa ibang shops mas mura.
    How about osrams:
    super, super70, bilux, sylvania-silverstars, silverstars, all weather
    Sep 2005
    Quote Originally Posted by puroy View Post
    OT: mga sir, baka meron kayong DIY HID replacement? ...
    Re: OT: make sure that you are installing the HID in a Projector-Type headlamp assembly di tulad ng mga ogag na naglalagay ng HID sa pang-Halogen na headlamp assembly.
    You can get HIDs for about Php8k which includes the installation.
    Jul 2006
    The bulbs do not give the best visibility. The lens do.
    Bluish/white light is hard to see in the rain. Paalala ko lang.
    *russpogie - why in a projector headlight? diba dami nang installed sa mga h4/halogen headlight assembly?
    Sep 2005
    Quote Originally Posted by ineedmorehp View Post
    That's exactly my point. Halogen the headlamp assembly was designed primarily for HALOGEN lamps, nothing else. The projector type headlamp assembly was designed initially for Halogen lamps. The main difference is that the projector type gives the light source a cleaner and crisp projection of light and maintains the correct cut-off point on the beam so as not to blind other drivers on the road. The projector type headlamp assembly system is perfect for HIDs thus BMW and other premium car manucaturers use this headlamp assembly for HIDs.
    Sep 2005
    Quote Originally Posted by mbeige View Post
    Tama. Usually color temperature of anything 6000K and above. By the way, the K in 6000K denotes color temperature, not the brightness. Brightness is measured by Lumens.
    Aug 2006
    Quote Originally Posted by russpogi View Post
    I didn't understand almost none of what you said above...
    On the side note, projector headlights aren't meant for HID's only, and there are non-projectors that are made for HID's... Check on the previous-gen Acura CL, they have non-projector headlights but they come with HID's and they do not blind drivers in the oncoming traffic at all... On the other hand, take the USDM Acura Integra, they came with projector headlights and halogen bulbs, try putting HIDs on them and you'll see some mad glares...
    There are projector headlgihts that are meant and NOT meant for HID's, and there are non-projectors that ARE meant and not meant for HIDs... With it being a projector does not always mean it's good with HIDs...
    Sep 2005
    Quote Originally Posted by blink21me View Post
    Nakakalito ba pagkasulat ko? Sorry po!
    Anyways, PhDM cars are normally equipped with halogen lamps and retrofit HIDs in a halogen headdlamp causes the light to be scattered thus blinding oncoming drivers, as well as the driver of the car infront. Projector type headlamp assemblys are initially meant for Halogen pero now it's desinged to accomodate either halogen or HID and still giving the owner a very good cutoff point for the beam.
    The main point here is that if a car owner decides to use HID in his car, he should make sure that the headlight assembly was desinged to accomodate such. If not, the owner should get the proper headlight assembly to accomodate the HID.
    Apr 2006
    I use Narva Arctic Blues myself. At 4000K, it's the same as the Philips Blue Vision but costs less. Or you can go 5000K with the Philips Diamond Vision, if its street legal there. That is, if you want to use stock wiring. Otherwise, go for a HID conversion at 6500K and upwards.
    Aug 2006
    now that's a thumbsup . Pero matanong ko lang, anong car ba yung originally gawa ng pilipino? Ngayon ko lang kase narinig yung PhDM, lol.
    Pedeng sumagot? Mga assembled jeep na ang headlights nila ay sa mga puno nakatutok, kaya kahit mag low beam sila, nasisilaw pa ding ang kasalubong nila. Kainis dami nito sa Cavite.
    Sep 2005
    Ah! Hehehe!
    Yung PhDM are vehicles designed/marketed for the Philippine market.
    Originally pinoy? Ewan. Wala yata eh.
    Jul 2006
    Here are my two babes H4 and HB (Fog Lamps)
    Both running 8000K
    If you are interested in getting a super cool look you can PM me.
    Price $150.00 U.S. price depends on current exchange rate.
    Aug 2006
    Quote Originally Posted by Slick50 View Post
    I think you can find PIAA's everywhere for much lower price
headlight bulb
