Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    I have not done this modification. But when I'm at Jorge's and Jemson's place [ Jemson's Auto Electrical and Jorge's Radiator Shop | Facebook ] I saw them (usually Roy) doing it on a lot of customers' cars. It makes the gauges look better and possibly easier to see while driving. Feels like a poor man's optitron or fine vision gauge.
    Photo of the bulb used [they have shorter ones depending on the size of the bulb cavity]:
    Suzuki Jimny gauge cluster being fitted (and the lens being cleaned but usually there is no need to remove the lens):
    Jemson thread at Tsikot.com (for the other works they do): http://tsikot.com/forums/car-securit...mber%5D-64981/
    You can buy your own bulbs or have the shop source them for you for a nominal mark up.
    Sep 2011
    Doc, how much po average price with parts and labors na for this mod?
    Nissan Patrol GU (2001 up) gauge cluster getting ready for the LED mod:
    Jun 2007
    doc otep, how much kaya ito?
    Dec 2007
    You have Neo wedge for your gauge lights not the T10 type for twist wedge. The bulbs are fixed they cannot be removed.
    Those are hard to find in the Philippines.
    Sir meron na po. 300 a pair ata? They did a patrol using said bulbs po.
    Nov 2011
    Doc Otep, pwede po ba to sa CR-V '03?? magkano kaya aabutin?
    thanks so much!
    Jan 2008
    dito sa las pinas meron na yan ganyan bulb.. pwede naman palitan yung socket ng led bulb.... sa blue zone auto accessories meron
    ayoko lang tanggalin yung panel ko eh baka pagmulan pa ng mga ingay.. papalitan ko na lang pag may pundi na
    most likely pwede. price will depend on how many LEDs will be used.
    Jan 2003
    DIY my vitara last july 2011
    cluster guage, aircon panel, clock and the shifter indicator
    Very nice impulzz! Looks like Optitron
    Dec 2012
    120 per bulb tpos labor lang sa may sucat
    Jan 2011
    Quote Originally Posted by Accentnitox View Post
    Saan sa Sucat boss? Looking dito nga bandang south area. Appreciate for contact number or name ng store... TIA.
    Dec 2012
    Quote Originally Posted by tuazon7 View Post
    Actually paps wala shop. Pm your contact number. Sa may ireneville.
    mga sir, im planning to mod my panel gauge lights to LED, pero syempre di ako gagawa sa electrician na lang, ang tanong ko, possible ba na may masira na gauge ko? (eg speedometer, fuel gauge, temp, rpm) baka kasi may chances na biglang mag loko or what. kaya natatakot ako ipagawa.
    May 2007
    Quote Originally Posted by impulzz View Post
    Nice! Question though, is it bright enough for daytime use? Para sana optitron na talaga ang dating.
    Sent from my iPad using Tapatalk HD
    Jul 2012
    Ayus yang DIY na yan ah. Sana merong guide step by step.
    Dec 2008
    yung ganito na bolt on LED.. ano kaya code or tawag..
    may alam ba kayong nagbebenta or nagkakabit.? bandang south sana..
    las pinas, pque or cavite area.. TIA
    Dec 2008
    correction..
    #24 pala yung sa taas not #74
    so sa civic EK ay tatlong klase pala..
    #74(smallest rice bulb) #24(midsize rice bulb) #194(big rice bulb or peanut bulb..? i'm not sure heheh..)
    i can't find a #24 kaya naghanap na lang me ng 3 watts na #74 then bukaka na lang yung paa para
    umipit sa loob ng socket na pang #24... kumasya naman and mukhang di rin basta-basta mabubunot..
    for the mods.. i have to remove the diffuser and amber print sa likod ng face using cotton buds and alcohol..
    then use a transparent headlight film (blue and red) para magkakulay... maganda rin naman.. kung naging
    maganda lang placement ng mga bulbs sa gauges ng EK ay mas maganda siguro effect niya.. kaso puro
    alanganin yung puwesto ng mga bulbs sa ek eh.. i saw a project at HCP na inalis din yung diffuser at amber..
    then LED's in PCB's complete with resistor and voltage regulator pa ang nakalagay sa likod ng bawat gauges..
    ang galing!!
    Oct 2005
    Quote Originally Posted by RVRSSG2.0 View Post
    No, as per my Sentra. It is brighter than stock, but not bright enough to look like an Optitron. Saka ang instrument panel design kasi ng 90s car ibang iba sa cars of late na parang digital/color etc. Kaya hindi same effect.
LED Gauge Mod
