There's this moisture build-up in my left headlight, doesnt seem to go away.
How do i get rid of it and make sure doesnt occur again?
My ride is a civic98.
OEM headlamps ba gamit nyo? napalinis na yung lamps dati? minsan kasi pag nagalaw na yung seal sa lamps at hindi maganda yung pag reseal magkaka moisture na. Pag very little moisture usually mawawala naman yun pag naka on na yung headlights.
bro -- baka may naiwan lang maliliit na water beads sa headlamps mo kaya ganyan
this happened to me. i had my headlamps cleaned by a car shop and after they used their hair dryer to dry it, nag karoon pa rin ng moisture sa loob
napansin ko na may water beads at the bottom of the headlamp.
so what i did was to just remove the bulb keep the headlamp open from the back. then iniwan kong ganito the whole day including leaving the car under the sun at high noon
by late afternoon, i returned the bulb, reattached the cover at the back and nawala na ang moisture
sa akin pabalik balik na. mawawala tapos babalik. nabuksan na kasi headlight ko eh. pero yung isa headlight ko. wala naman. dipa kasi nabuksan
bro -- ganun na ganun yung problema ko sa lynx headlight. pagkatapos kong gawin yun na post ko, wala ng problema hanggang ngayonOriginally Posted by onedayoldchick
mga boys, kumuha kayong isang pakete na silica gel (dami sa mga hardware), taliin nyo yung silica gel container ng maayos, close the hole where the headlite is inserted and leave it under the sun. simot yan
wala nang moisture headlite ko. dinagdagan lang ng sandamukal na silicom sealant.
I just remounted the rubber grommet behind the headlamp socket, wala nang moisture after.
ganun po din sa akin problema sa moiste.. kasi po nag change ako ng headlights ko ng angle eyes daw sa corolla tapos kung malamig sa right side ng headlight ko may moiste.. hindi kay maluwag ang bulb socket ko? uhmm.. i wonder ???
sir theveed mgandang idea yn mski dko p n try. msubukan nga. saludo ako syo sir!Originally Posted by theveed
