Results 1 to 9 of 9
- Jul 2010
- 21
September 10th, 2012 10:37 PM #1Goodpm guys may improvement ba putting wiring harness on halogen headlamps?ilan percentage kaya idadag sa output?advisable ba for newly bought car? just bought a 2012 hilux and parang nahihina-an ako sa output medium tint lang ako sa front..need to increase the out palagi kasi ako out of town and usually gabi na ako bumabyahe. any suggestions?hid on foglamps kaya using 4300k? thanks in advance sa replies guys.
- Dec 2002
- 2,335
September 11th, 2012 11:07 AM #2since bago pa yung oto, walang effect. you do that when you use hi power, aftermarket halogen bulbs. try mo muna Philips XV or OSram night breakers, mga 15-20% increase. stock wattage yan. fogs na hid, sayang lang pero mo and it will glare other motorists. FYI, sa lighting upgrade, yung expected increase sa intensity, proportion sa money you put in.
- Jan 2008
- 4,726
September 11th, 2012 11:30 AM #3simple lang solution dyan.. remove your tints!! kahit ano pa ilaw lagay mo dyan basta may tint ka kahit pa magic yan ma reduce pa din ang visibility mo lalo na pag maulan tapos asphalt yung kalsada... pansin mo kahit tanghaling tapat at tirik ang araw eh parang alas singko na ng hapon sa loob ng kotse mo gawa ng tint..
kung gusto mo pa din ng tint eh ingat ka na lang sa pag drive mo..
September 11th, 2012 03:10 PM #4
is it safe to upgrade to 100/90w bulbs (for a new car like hilux) or there's a need to add relays, ceramic plugs etc.?
- Jan 2008
- 4,726
September 11th, 2012 03:46 PM #5need to add relays and ceramic sockets.. malulusaw yung stock socket mo..need mo din bigger wires to maximize yung power ng bulb
also make sure na turn off nyo yung head lights nyo kung ma traffic tapos matagal pa bago umusad kasi iinit ng sobra yung housing nyo at iitim agad yung loob...
September 11th, 2012 05:25 PM #6
hindi kaya ma void yung warranty ng new car pag nag rewire at nag add ng relays?
- Jan 2008
- 4,726
September 11th, 2012 05:47 PM #7if i'm the one to install it, i can wire without tampering the original like a plug ang play device
- Jul 2010
- 21
September 11th, 2012 09:09 PM #9thanks for the reply guys..will use philips xv or osram nb plus.. h4 for headlamps and hb4/9006 bulb type for fog lamps tama po ba guys for the hilux?..how about using xv or nb plus for headlamps ang will use a wurth 4800k gold series bulb for foglamps?maganda kaya output especially sa byahe? baka may ma suggest kayo guys for magandang pairing for Headlamps and fog lamps? thanks thanks..
*sir gary.. maganda sana yun retrofit niyo..ipon muna hehe.. thanks for the reply.
How about 97 LXi?
Civic horsepower
