Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Neat install
    hindi ba magalaw yan kapag nalulubak?
    Signature
    dirty car!!
    ahrharharh
    thanks!
    boybi...may vibration pero secured naman po ang lahat ng connections....hindi siya ung gegewang gewang
    nice plates... lolz
    as always clean installation from DIY baby Glennster
    what thickness of azngle bar did you use? i notice that it seemed small. anyways this is what is what i did and the thickness of the angle bar with a separate bracket for the plate so that i can tighten the bracket to the bumper without damage to the plate.
    http://www.tsikot.com/forums/gallery/thumbnails/456.jpg
    http://www.tsikot.com/forums/gallery/thumbnails/457.jpg
    sir arb..i used aluminum angle bar care of sir otep....hmmm...un sayo po ba naka screw sa ibabaw ng bumper?
    ako kasi i cant afford to drill a hole sa bumper..so im using the hole for the plates.bumili nalang po ako ng magandang bolt para di maputol and double nut para mas secure.
    need4speed..thanks!!herhehrherher
    kimpoy...katulong lang po ako ni kuya ronald sa g&s...herhehrher
    Sir Glenn anong model yan HELLA? balak ko rin mag lagay ng yellow fog/driving lamps sa license plate holes ng LC ko.
    Baduy... :P hehehehe...
    Mas bagay ata sa Frontier na blue yan. :D
    papa vinj:charing ka talaga...uy sorry..di ako makapunta ha...text me pag nasa bahay na..herhehrerh
    siakol...alam ko wala nang nabibili nito kasi old stock pa siya.pero try ,mo na rin. RALLY 1000 UNg model po niya.maganda siya...chaka orig naman po na hella ito...
    i used the plate no. holes to mount the bracket with supporting brackets at the back of the bumper that attaches to the body. looking from the front most people would say that sayang that i made a hole in the bumper.
    side view:
    http://www.tsikot.com/forums/gallery/thumbnails/458.jpg
    yep!!!saw it!!!...maybe i need the bracket sa likod ng bumper..hmm...ill see what i can do...
    thanks sir arb!
  15. #15
    bagay!
    The Hella FF1000 are also good(2.8K each) and the Illuminator(8K each) are the best.(Han's Tools) You can also check the beam profile sa Hella site so that you can decide what's the best for you. Very informative yung site ng Hella. I installed a Comet 550 driving lights (I'm going for the FF1000 next time) and a FF75 fogs on my rig. Fog lamps have short and wide beam pattern giving you better foreground illumination. Driving lights have long, very directional beam pattern giving you better illumination at high speed to allow you to react to any debris (or whatever) on the road. Driving lights are mounted on top of the bumper and fogs normally below the bumper. You can also install all-weather H3 bulbs on this lamps para better illumination kung umuulan. The OSRAM Silverstar(800/pair) are also very good or the Flosser All weather (400/pair).
    Just sharing my experience and I hope Glennster won't mind.
    Jan 2003
    ang ganda! pwede rin ba sa tsikot ko? i mean pansamantala lang balak kong bumili ng TJM bumps.. hehe ;)
    sir gary q..i definitely dont mind!!!we appreciate the good info!!!
    yep!!i opt for this driving lights because it is very useful especially during long drives in the highway of provinces...baka may mga baka o kambing na tumatawid..ehrherhehrehr
    hmmmm...naghahanap nga po ako ng bulb para dito na all weather...meron na rin pala...
    thanks sir gary!!
    noteworthy:angle bar lang naman po ang kailangan niyo for the mounting plus reinforcements sa bracketing kung hindi kayo secured....goodluck!
    question po..
    meron bang driving light na nase-set mo yung focus or yung bagsak ng light sa road? ..
    ang gusto ko sana eh yung fog light/driving light na naka-focus sa right side ng road para makita mo yung mga tao/bicycle na ayaw tumabi na halos mahagip mo dahil naka hi-beam ang kasalubong mo.. kumbaga eh parang hi-beam sya sa farther right side na hindi masisilaw yung incoming vehicle..
    medyo weird ba? ..
    ganun naman tal;aga dapat eh.
    check out the website of hella...you will see the difference between foglights and driving lights.
    you should choose whatever caters to your needs.magkaiba sila eh.
  20. #20
    revoGSX: if you want it more to the right you can adjust it naman coz left to right and up/down ang pivot nun. If you want to see more on the side you need a fog lamp. Ganun ang beam pattern nun. As mentioned you have to install it below the bumper
my new hella driving lamps ala otep rivera
