Results 1 to 14 of 14
    mga gurus i need help, paano ba i adjust ang headlight angle ng altis? kasi laging loaded ang car ngayon so may tendency na maka glare so plano ko i adjust pababa ang tutok ng HL ..
    the prob is di ko makita ang pointer na ina adjust unlike sa ibang cars na pipihitin lang yung screw to adjust sa altis wala ..
    TIA\
    dibaka hindi mo na kailangan i adjust yan kung hindi mo naman ginalaw or pinalitan ang headlight mo kasi nakafactory preset na yan.
    Quote Originally Posted by raine View Post
    orig HL po pero nagalaw na dati yung alignment .. aadjust ko lang po pababa.
    Aug 2005
    I was also wondering kung paano i-adjust ang headlight ng ZZ namin.
    OT. We have a 2002 1.6E ZZ. Nasaan ang antenna? :D
    pero na adjust ito dati ng LAcars ..
    sir mel, wala pong antenna zz's natin .. i also had the same question dati then nung change ako ng HU wala ring antenna ..
    Aug 2005
    Quote Originally Posted by s_quilicot View Post
    Dapat may antenna ang FM para makasagap ng signal. Di kaya nakatago sa loob?
    OT pa rin
    Aug 2005
    OT pa rin
    OT pa rin
    wala rin po .. baka built in sa new gen HU di kaya?
    Aug 2006
    Meron yan antenna, printed na sa glass.
    Sa Innova nasa quarter panel glass sa likod, sa Altis yata nakahalo na sa rear window defogger.
    May 2007
    Hindi ba automatic leverer ang lights mo?
    Kung hindi may adjustment yan sa may headlamp assembly, its torx screw adjuster. One adjust the lights up and down and the other adjust side to side. Make sure na pumarada ka sa level area w/ a wall at doon ang aiming mo. Good luck
    Jul 2006
    Take a look at the two holes. Nandyan yung adjustment "gear" you will need a (+) screwdriver. Or kung wala dyan maybe you need to remove the front fender plastic covers (from inside the wheel well). Some modern cars are so compact they forgot to add the adjustment knobs to be easily reached from the engine bay. That's how it is in the Jazz maybe your Corolla is the same.
    Either way nasa manual dapat yan.
    Jul 2006
    Actually minsan sablay ang factory presets. It's always good to make sure yourself (maybe I just don't trust the factory that much )
    ok na naayos kona .. post pics bukas ..
    Quote Originally Posted by v6dreamer View Post
    nakita ko na sir finally! tnx
How to adjust Headlight on 1st gen altis
