Results 1 to 6 of 6
    Guys I need ur help medyo walang kaalam alam sa car maintenance e. I drive an a/t Civic vti. last nyt napansin ko di umiilaw yung drive indicator ko sa kambyo. ano kaya problem nito?
    Might be a burned out bulb since you spend most of your time in 'D'.
    Getting to the bulb is not a complex task. Just unscrew the screws holding the instrument cluster to the dashboard, tip it forward and you will see the access holes for the bulbs.
    You may need to pull some wiring in the process but most of the wiring is idiot-proof (it will not go into the wrong connector).
    Try to borrow a bulb from lesser used gear settings.
    Sir Otep, I didnt explain it well.Lahat kasi ng gear settings (eg. D, R, P,N,D2) walang ilaw e. busted kaya lahat?
    Check first the fuses. If you don't know which is the correct fuse, just check them all. Dapat walang burned or tripped fuse.
    Then check the connector behind the gauge cluster. Baka yung connector sa likod ang maluwag.
    Thanks Sir Otep. Il try that.
    Sep 2004
    Yup, most probably busted fuse lang.
    Kung Honda, "Interior Lights" ang fuse para sa dashboard, located in the engine bay
light indicator
