Results 1 to 9 of 9
May 31st, 2007 02:09 PM #1
Peeps, tanong ko lang po kung bakit umiilaw yung ABS light on the dashboard sa may ibaba ng odometer pero minsan naman hindi. Meron po bang problema sa auto ko?
May 31st, 2007 02:31 PM #2
pachek mo, dapat off ang ABS light while driving..ON lang yan sandali after putting the key at ON position then off agad.
May 31st, 2007 02:38 PM #3
pero minsan umiilaw sya habang nagddrive ako pero minsan naman hindi, papacheck ko na rin, baka siguro false alarm din
May 31st, 2007 03:15 PM #4
Sensor siguro might be grounded. Any brake repairs recently? Wading through deep water?
May 31st, 2007 03:20 PM #5
pag nakailaw abs indicator meaning naka dis-able ang abs function ng sasakyan, kailangan mapa scan mo ang abs module para malaman ang fault. or kung matiyaga ka inspect mo muna ang mga abs sensor sometimes loose connection or madumi ang tone ring ang most common problem.
May 31st, 2007 04:13 PM #6
yes, yung gulong ko nung last time na umulan ng super lakas, binaha sya almost 50% ng gulong naka-immerse sa tubig. thanks for the info. sana nga po sensor lang na madumi, hehe..
June 1st, 2007 12:41 AM #7
palinis mo lang yun brakes mo. baka nag stuck one of the piston. damay mo din yun ABS sensor niya. Buti di ako nagkaganyan last Tuesday pero mabasa yun carpet ko
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Jun 2007
- 8
June 6th, 2007 11:52 AM #9jusipus,
we have the same problem. can you tell me kung ano ang ginawa mo to correct it. Tnx in advance. Or better yet, kung hindi abala sa yo, you can e-mail me the procedure * yaj_319*yahoo.com. Sana matulungan mo ako, worried din ako sa intermittent warning light ng ABS ko.
Tnx ulit.
yung local Toyota version na 2.8li diesel ay parang Prado nga lang. same with the Fortuner engine? ...
Land Cruiser 250
