Results 1 to 10 of 10
    Mar 2004
    mga tol, nagkabit ako nang wiring kit na to sa aking toyota revo, ngayon napansin ko na di pala umiilaw yung High beam indicator sa dashboard pag nag switch to high beam ako.... pero pag yung stock wiring ang ginamit ko, ok naman.... patulong naman po.... dami na sa akin galit kasi naiiwan ko nakahigh yung headlighs
    yan din problem ng mag upgrade ako kaya tinagal ko na lang.
    baka mali lang pagkakabit sa wires, yung sa akin, narva harness and relays, ok naman.
    Signature
    pacheck mo lang sa electrician..mahirap mag diagnos nang ganyang mga problema dito...
    do it asap..electrical yan..baka may madamay pang iba.
    Mar 2004
    fixed it na po... meron daw wiring set na pang toyota talaga, anyways nag re-search na lang ako, nakakuha ako nang schematics..... tapos gumawa ako nang work around so ayun ok na... ayaw ko kasi modify yung stock na wiring ko eh
    Aug 2003
    gumamit din ako before ng narva kit sa corolla ko. problem is pag naka high beam ako. napansin ko na mahina yung ilaw ng high beam sa guage yung color blue. parang pigil yung power kaya inalis ko nalang
    Jan 2003
    meron specific narva kits for toyota. im also using a narva kit, no problems naman.
    Quote Originally Posted by boybi
    san mo nabili boybi meron kaya for xwind or isuzu
    Sounds familiar...
    When we have our relay wirings done at Reys, they add an additional wire for something to the instrument cluster of the Toyotas and Isuzus to fix that problem (they specifically mentioned it's for the high beam). They say without it, the high beam and low beam work at the same time when you're on the high beam setting.
    Jan 2003
    hmmmmm... diba sa orig wiring naka tap ang mga add-on relays... buti na lang nung DIY-relay ko lancer ko di ako nag ka problema... also installed a switch para i can switch on my low beam when my high beam is on... works great for those jeeps and buses
Narva Headlight Relays
