Results 1 to 1 of 1
October 3rd, 2005 03:19 PM #1
Inputs naman guys. Ride is a 99 local Isuzu Trooper(4jg2).
Few months ago, nag-iilaw yung light(brake warning) sa instrument panel ko. ito ay after na irelease ko yung brake pedal while driving. then few seconds mawawala. meron din time na di sya nawawala(light) for more than a minute after releasing the brake pedal while driving also. Try to clean the plug connected to the brake master reservoir. pati yung terminal dun at medyo madumi na. baka nasoshort na. Test drive, di na nag-ilaw.
Then yesterday going to megamall, bumalik yung pag ilaw. ngayon consistent na sya after release ng brake pedal ilaw sya for almost 2 sec. then disappear.
This morning clean again the terminal, ilaw pa rin after release ng brake pedal.
Remove the terminal sa brake master resevoir, ilaw pa rin pag release ng brake pedal(so di nato problem i.e. yung terminal).
Meron pa ba nagtitriger nun electrically except sa handbrake lever? OUt muna natin yun low vacuum at puro electrical muna tayo. TIA
high idle RPM at engine start
