Results 1 to 20 of 20
    Apr 2006
    the plastic lens of my headlamp is becoming hazy. bulbs used is still the 55/60 watt. the upper portion is getting hazed just like the water marks on aquariums. how would you clean or remove this?
    Apr 2005
    there are shops who do headlight cleaning (i.e. wizzards, bigberts). inquire ka na lang bro.
    Aug 2004
    had our headlight cleaned at bigberts. ganda naman ang pagkagawa nila. pa check mo nalang bro, kasi may mga headlight raw na hindi pwede linisin.
    yep dalhin mo sa big berts....sa kanila ko pinalinis headlamps ko...mas madaling matatapos iyan kung dadalhin mo sa kanila na nakahiwalay na sa kotse...
    Apr 2006
    is it hazy means parang lumalabo?? nawawala yung transparency niya?
    labas ba o loob? Pag labas, you need to polish it, kung malala, even have to sand it a little... pag loob usually cleaning lang.
    Apr 2006
    sa labas lumalabo, parang nabawasan transparency. it's a bit rough. i'll try big berts when i get to manila. sa pangasinan pa ako kasi. what polish can you use to clean it?
    do they also clean tail lights? yung mga tipong water stains
    how much do they charge?
    Taillights, as in loob ng taillight?
    ^^yep. nagka leak kasi dati eh
    Apr 2006
    try Meguiar's PlastX first, if you can.
    Before:
    After:
    Using PlastX and some elbow power.
    Some links
    here
    and
    here
    kokonat: PlastX is great, but in your case, any body polish/compound will work since glass sya... (for the headlights, at least)...
    Used PlastX on one of our customer's Jazz a couple of months ago, grabe parang nawala yung lens sa harap hehe.
    Apr 2006
    Quote Originally Posted by raquino
    BTW, I was referring to this post, not the taillights.
    so do they clean tail lights ba? the euro thingy kind
    Apr 2006
    Can BigBert clean the headlights of a Honda Civic '97? How much kaya? My sister's car is long due for this, and I've been bugging her to replace it. BigBert might be a good option.
    Ganito talaga ang Civic, dumudumi yung loob ng lens. I had it cleaned before and nasira yung silver lining sa loob; so I had to replace them.
    Naku, yun sakin din medyo madumi na. Sir Theveed, pa PM din ako ako cleaning ng headlight EK civic. Pwede bang sa inyo na din papa tanggal yung headlight? nahihirapan akong mag baklas nito eh.
    Tawag nalang po kayo sa shop hehe...
    do they clean the inside of the headlites too?
    we do po.
hazy lens of clear headlamps
