Results 1 to 10 of 34
January 16th, 2015 12:36 PM #1
Kamusta itong brand? Ok ba katagalan?
Ang mahal kasi ng oem sa casa e.Last edited by harold13; January 16th, 2015 at 12:41 PM.
January 17th, 2015 12:14 AM #2
Okay din. Kaso marupok ung lens. So pag mag aadjust ka ng aim, wag mo pepwersahin ung lens,
Malakas din mag init, kaya thermal shock will be an issue, dahil un nga, marupok lens, mabilis mag crack, palamigin muna before doing a cold car wash, if ever.
January 17th, 2015 01:15 AM #3
Ah hassle pala ito.nabasa ko din mabilis mag init lens.mukhang hindi ito pang matagalan lalo na sa long drive. Sige ill look for an oem kahit mahal.
- Apr 2008
- 6,235
January 17th, 2015 01:38 AM #4Gumagamit ako ng Esuse aftermarket fogs para sa Revo. Ok naman siya. Ilang beses na dumaan sa baha na nakabukas, di napasukan ng tubig, malinaw parin ang lens. Mga 3 years na yan ngayon, parang bago parin.
Sent from my GT-I9100 using Tapatalk 2
January 17th, 2015 10:51 AM #6
ESUSE fog lights on my FD lasted around 2 years. Problem is, the silver reflective coating blackens with use and the plastic above the bulb melts. The lens is also plastic. This is particularly true for most, if not all, non-OEM fog lamp assemblies.
Anyway, your mileage will vary depending on how often you use them.
Have since then bought a used OEM fog light assembly (Stanley). Even when one of my foglamp was damaged due to a flying road debris, it's still watertight. And as you can see, the lens is made of glass.
January 17th, 2015 12:45 PM #8
Mas maganda orig padin no? Ito pinicturan ko sa showroom.toyota koito.
- Apr 2013
- 236
January 17th, 2015 12:53 PM #9Iba pa din ang OEM na koito and stanley. Siguradong tatagal and iba din ang buga ng ilaw.
- Oct 2009
- 2,271
January 17th, 2015 01:59 PM #10ung sa vti ko gulat ako simula pa nung bago 1996 .2012 nung binuksan ko para bugahan ng ibang kulay ung paligid ng loob .parang bago parin ung loob at hindi manlang nagka umido.ung loob mas matibay talaga ang mga sync saka glass kaysa sa mga modelo ngayon halos puro plastic na lahat.housing pati lens plastic nadin.
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
