Results 1 to 4 of 4
    Apr 2013
    Hi guys! where can I buy a LED strip light that you can use on your car interior/exterior that can be wire-tapped directly to the car power (12v, no more adapters) and at the same time can be cut into shorter length or single LED?
    I saw some LED strips at CDR King but I am not sure if it can be tapped directly to car power? It says the rated input power is DC 12V – 3A, but this comes with an adapter for AC use.
    I saw some in BLADE. It is the type you can trim off to fit whatever you want to put on to. P900.
    How about yung sa motorcycle shops? Daming LED/LED blocks on display. Di ba direct installation ma mga yun? Or may relay/adapter din?
    may nakita akong ganyan sa ace hardware dati. for automotive use talaga according to the packaging
Where to buy LED strip for cars that you can plug or tap directly to car power?
