Results 1 to 4 of 4
July 24th, 2009 04:14 PM #1
mga sir, magpapainstall ako ng additional fog lamps sa tsikot ko. civic 02. plan ko is yung mga bilog na small size lang na usually kinakabit sa mga civic 97-00. then question ko is possible naman na HID yung isalpak ko dun db? tapos additional question is pwede ko din po ba gawing blinker yung foglamps? like yung nakikita ko sa mga motor minsan na ang lakas ng blinker nila na pure white ang buga? HID yun ryt? kung hindi man sir tanong ko nadin po kung anu po yun?
possible po ba na 2 uses ng foglamps ko? pag everyday use fog lamps sha then pag carshow naman gagawin ko shang blinker.. lalagyan ko nalang ng parang switch.. possible kaya tong naisip ko mga experts? TIA!
July 24th, 2009 04:49 PM #2
"Blinker insert" can be bought at Concorde, 3 wire blinker with U shape bulb cost around 500+ petot/pair and the 2 wire blinker with rod shaped bulb cost around 300++ petot/pair. All bulbs have rubber condom replacement of colors red, blue, amber and it is bundled with strobe controller. You can insert it on your headlight assembly or other car light casing.
July 25th, 2009 02:56 PM #3
pwede mo lagyan ng hid yun. kung fog lamps na bilog kukunin mo masmaganda kasi malayo ang buga niyan kesa sa rectangular shapes.
then check mo nalang kung may umbrella sa loob yung fogs and gaano kalalim kasi may mga na encounter na kami na murang foglamps na may umbrella then h3 bulb types gamit hindi malagyan ng ordinary h3 hid bulb kasi sobrang babaw at tumatama yung umbrella like nito sa loob. so we had to remove it . but there is actually a h3 hid bulb na maiksi we call it h3-c masmahal lang ng konti pero i doubt may nagiimport nun. kami naman if you want that kind of bulb special order pa yun so you have to wait.
then for the blinker. I've tried getting type r na blinker im just not sure if it is same with the type r available here kung meron man as we all know type r na brand parang generic na din kasi.
yung nabili ko 2 set ng blinker may condom din siya pwede mo gawin red blue or white lang then may controller ng speed ng bulb kung gaano kabilis mag blink tinetesting ko palang that time nung binilisan ko napundi agad
2 sets sira agad. sample siya from my supplier so hindi ko na inimport ewan ko lang kung may ganun dito at kung meron man same sila. just a heads up total tetestingin niyo naman eh
might as well set the speed to the highest and see kung ganun din mangyari pag napundi well you know what quality it is
hindi ko po sinisiraan ang ano mang brand. i'm not selling strobe lights or blinkers balak ko lang dati mag import kaya nag test ako ng sample and yun ang experience ko . ayaw ko naman magbenta ng sirain kaya di ko na tinuloy
pero pwede yan plan niyo lalagyan ng blinker ang fogs
I have also a sample here led blinkers. butasan mo fogs mo then lagay sa loob ok siya malakas. pero hindi ako nagbeebnta sample lang siya tinesting ko oks. china made
share ko lang
July 25th, 2009 03:15 PM #4
