Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    eto po yung pics ng improvised lamp stay ni OTEP
    after lagyan ng anzahl primer
    after bugahan ng quick drying paint
    after butasan
    habang kinakabit
    final look
    Nice! :D Howd you mount the angle bar to the bumper? Thru the license plate screws? ingenious!
    Mukhang delikado yang aux lights sa pwesto nya. Kala ko naman mounted above the bumper. Sana naway wag makanti ng mga kariton, sidecars at kapwa motorista. ;)
    otep just left our shop....
    mejo nakalbas nga ung foglamps...ungas...kasya kaya above the bumper ko kung gagawin ko sakin yan?
    Jun 2003
    Astig! Sir otep paano nyo pinang kontra yung isa?
    or isa lang ang linagay nyo and kinapit sa screwhole ng lisence plate?
    Pwede, but you'd have to mount the angle bar in reverse position as OTEP's. 1-1/2" x 1-1/2" bar should lift it clear above your bumper with ample space for plate number and aux lights holes.
    i have my aux lamps mounted that way for 5 years already. i am grateful that i have not bumped anyone still and nobody has backed up on me. i was once backed up by an isuzu elf, but that time i did not mount it because i will have my aircon cleaned and had to take it out to get the grille off.
    Maraming salamat nga pala kina Chieffy, Sheep, Glennster, and all the peeps who helped me out on this one.
    Sir Sheep, na kay Glenn po yung isang angle bar. I hope you don't mind. I used the 1.5" x 1.5" after some expert trimming by Chieffy.
    Napansin ko lang parang mas maliwanag yung kaliwang lamp kaysa sa kanan. Sa bulb lang kaya 'yun? May dalawang extra H3 bulbs pa naman ako dito.
    Medyo may vibration ang mount. Pero may idea na ko on how to eliminate it. Kaya lang wala pa kong time. Sana tulungan ulit ako ni Chieffy. hehehe. Expert talaga siya. Btw, napansin niyo ba ang newly painted bumpers ko? Si Chieffy mismo ang gumawa niyan.
    Ok ahh ganda ng dating bagay sa Uniform ni OTEP hehehhehe
    ungas..sige subukan ko tom or sa saturday...may 2 hellas kasi dito na dapat sa lariat ni papa ilalagay eh...eh naliliitan kami...
    tingnan ko kung pwede..ayoko din mawala ang bumpers ko (ung 2 rubber bumpers)..nagagamit ko sa mga mokong un eh...ehrherhehr
    OTEP:thanks sa angle bar!!!
    pati narin kay chieffy!
    Chieffy,
    Nasan yung picture na kasama si angst? hehehe.
    naku, hindi pwde sa dito sa amin yang ganyang setup ng foglamps. daming g*gong tricycle drivers dito. kaya hindi ako makapagkabit ng foglamps dahil mas nakausli yung ilaw kesa sa bumper.
    Signature
    Glenn,
    Pasalamat ka kay sir Sheep for the bar.
    sir sheeeeeeeeeeeppppppp
    salamaty pooooooooooowww!!!
    next project ito...ung lamps ko kasi nasa ilalim ng bumper eh...tanggalin ko na yun sabay kabit ng ibang fog lamps...
    sir kimpoy: baka naman meron ka pa jan....ehrhehrehrehr
    Mas Ok sana kung hindi yellow ang kulay hehehe
    Jun 2003
    sir glenn dont mention it din post ka na rin lang ng pics
    sir otep
    d ba mapupuwersa yung screw holes for lisence plate if dun lang nakakapit yung bar ? btw anong magic ang gagawin ninyo ni sir chieffy to remove vibrations? how about your next project do you plan to push thru just text me
    Sir sheep,
    Makapal naman po ang bumper ng Pajero. It was designed to hold the winch. Yung holes gumamit kami ng washers to distribute weight. Pero maglalagay na din siguro ako ng pang-kontra after ma-finalize kung may needed mods pa.
    Balak ko lagyan ng maikling tab which will bolt on sa lampstay and doon sa pagitan ng upper and lower section ng bumper (may existing hole na doon). Ser, may flatbar ka ba diyan? hehehe.
    Jun 2003
    Sir Otep
    meron nga po pero manipis lang and medyo wobbly if that is the correct way to describe it parang plehe (plumbers snake ) lang sya mas makapal n mas sturdy ng konti compared dun but it is not as flexible. sabihin nyo lang po if ok lang para madaanan nyo ulit kay mang ben
    Heto pa ang picture ni angst at ng Pajero.
    Sir Sheep,
    Kung kasing kapal po nung material ng angle bar, pwede na po iyon. I will take measurements later today. Thanks.
    hmmm napansin ko bakit OTEPS na ngayon ang plaka mo?
    Glenn, wala na akong fog lights meron pang kotse,
Improvised Angle Bar Lamp Stay
