Page 1 of 3 123 LastLast
Results 1 to 20 of 45
    guys help naman, im canvassing H.I.D anu kaya magandang brand [mga worth 5k budget ko mga paps] [civic hatchback auto] thank you!
    Quote Originally Posted by maypindot02 View Post
    kakapalan ko na mukha ko ah hehe volunteer ko sarili ko
    check this
    http://www.topgear.com.ph/board/index.php?topic=1680.0
    then para naman hindi bias basahin niyo din to
    www.xenonoptics.com/comments.php
    then you decide let me know hehehe
    haha. parang parehas lang yun sir xenon. hindi nga bias
    Oct 2009
    plus 1 kay xenonoptics. dyan ako kumuha ng hid for my city,, h4 hilo. very acomodating yan si philip. mabait. so far eh satisfied ako sa nabili ko. very worth it.
  5. #5
    What are your expectations? Sa tibay and sa lighting performance? Depende yan bro. Plug and play HID kits will cause glare to oncoming traffic. EG hatch eto with PNP hid kit.
    The hl's were even adjusted lower than stock and still the glare is way up the level of the cars windshield. Imagine ikaw yung kasalubong, masisilaw ka talaga. A good halogen bulb like Philips XP, PIAA or Raybrig will be better than this setup, for sure. Around 3k for a pair and better if you use clear DEPO headlights, 4k lang pair nun so total 7k lang. Walang babaguhin sa wiring harness mo tapos stock 55w kapa.
    Quote Originally Posted by xenonoptics View Post
    check this
    nice post, very reasonable din yung price, tanong ko lang, ano pagkakaiba
    ng generic h4 HID sa telescopic?
    thanks..
    Quote Originally Posted by lowrider03 View Post
    thanks..
    generic means walang brand. parang generic na gamot hehehe.
    telescopic naman po is yung type ng bulb for h4 , yan yung umaatras abante yung bulb para maging high or low yung buga ng hid bulb. compared to halogen a halogen bulb has 2 filaments kasi isa pang low isa pang high. ang low nasa harap ang high beam nasa likod ang filament. so in order for an h4 hid bulb to do the same
    nakalabas ang bulb pag low then naka atras naman pag high.
    meron din naman pong low hid high halogen na h4.
  8. #8
    hi xenonoptics,
    just sent you a private message.
    thanks.
    paalala lang: maging sensitive po tayo tungkol sa HID natin ha. thanks
  10. #10
    rion: ang ganda naman bro ng ginawa mo. Galing! I agree with you bro, respect for other motorists naman. If you want to improve lighting performance ng oto, get a good halogen bulb na lang.
    Pina HID ko yung Tucson. H4 type yung bulb nya. Pero I'm surprised kasi walang glare sa traffic. same cutoff sa stock halogens. Excellent lighting talaga. Philips Germany. Pero budget wise, hindi sya recommended.
    xenonoptics, talaga bang magiging ganun kataas ang high beam kapag telescopic HID?
  12. #12
    bro Philips does not manufacture H4 na HID.
    Aug 2005
    sample nga po ng buga against a wall. para makita ang pattern ng buga. TIA.
    *Starex_Gold,
    sir pwedeng pa post ng picture ng naka on ung headlight mo para makita ung buga na sinasabi ni sir meledson..thanks in advance...
    Mar 2005
    VTX na HID. 2 Years warranty.
    Medyo OT pero tungkol din sa HID , ano ba mas maganda kung retrofit to Projector head lamps or yung bolt on na projector or bumili na lang ng separate head light assembly like Depo brand na projector na talaga + HID na lang? Halos same lang kasi ng price ng bolt on at yung aftermarket na projector head light assembly eh.
    Parang ganito
    eto na po mga sir
    Low Beam: ISO100 ; Shutter Speed 1/80 ; F3.2 ; Exp. -1
    High Beam: ISO100 ; Shutter Speed 1/100 ; F3.2 ; Exp. -1
    Eto packaging:
    Gusto nyo bilihin? Pwede ko ibenta
    wow, for a reflector, those are quite decent cutoffs... but if you camera didn't decieve me, those lights is as not as bright as what it should seem...
    Quote Originally Posted by jmpet626 View Post
    If you ask me, mas maganda siguro kung real retrofit. I haven't tried retrofit personaly, but for bolt-on, I had a chance to try it out. I wasn't satisfied with the light output, but the cutoff of the gen1 was quite good. well it was a 6000k light, perhaps if it was 4300k, it would be different.
    rion, actually mas mukhang ganyan sa personal. pag ginawa kong +/-0 ang Exp. value, mukhang ma glare talaga.
    sinadya ko rin babaan ang Exp. value at taasan ang shutter speed para makita nyo yung cut off.
    nasubukan ko na sa highway. nasa Trooper ako tapos yan nasa likod ko. Same glare lang ng halogen bulbs. At na compare ko pa siya sa Toyota Vios na naka taiwan brand HID.
    well first of all ang topic ng thread na ito is looking for best hid . so we should stick to the topic on qualities of different hid brands.
    second for projector vs reflector headlights na naka hid, lamang ang projector in terms of yung walang glare na sinasabi . kasi nga po sa cut off.
    dahil po yan dito sa bakal na ito na nasa loob ng projector
    http://farm3.static.flickr.com/2133/...7b9d8f3780.jpg
    now with respect to all the sellers here and all the retrofitters and all customers who carries or believe in certain brands. sa price po na binabayaran natin you get what you paid for. ganun lang yun eh
    sa mga conscious about the glare medyo budgeted pwede kayo sa bolt on na projector, pag titipid talaga kayo pwede naman hid lang buy niyo what ever headlights you have, sa mga open budget pwede di kayo sa retrofit na projector mas mahal lang po konti pero as they say mas maganda buga and may brand din na hid ang package ok na din.
    sa high beam naman po na sinasabi
    ano ba purpose ng high beam eto google mo or sa wikipedia
    http://en.wikipedia.org/wiki/Headlamp
    Regulations and requirements
    Modern headlamps are electrically operated, positioned in pairs, one or two on each side of the front of a vehicle. A headlamp system is required to produce a low and a high beam, which may be achieved either by an individual lamp for each function or by a single multifunction lamp. High beams (called "main beams" or "full beams" or "driving beams" in some countries) cast most of their light straight ahead, maximizing seeing distance, but producing too much glare for safe use when other vehicles are present on the road. Because there is no special control of upward light, high beams also cause backdazzle from fog, rain and snow due to the retroreflection of the water droplets. Low beams (called "dipped beams" in some countries) have stricter control of upward light, and direct most of their light downward and either rightward (in right-traffic countries) or leftward (in left-traffic countries), to provide safe forward visibility without excessive glare or backdazzle.
    meron din disadvanatge talaga ang hid sa ordinary headlights pero yun nga kaya nga po pinapababaan nalang para malessen ang glare at wag na alisin yung cover sa harap at sa ilalim ng bulb. thats for h4.
    basahin niyo buong article para maintindihan niyo para saan ang low beam at high beam at bakit nakakasilaw ang high beam
    nandyan din may pic sinasabi paano ang light distribution or reflection palabas ng reflector headligt at projector headlight
    http://upload.wikimedia.org/wikipedi..._schematic.png
    dun sa eg naman well either hindi maayus ang focus niyan o may mali sa h4 bulb na kinabit hehe kasi eto kinabitan namin depo headlights nalang nga yan eh
    http://sphotos.ak.fbcdn.net/hphotos-..._4924342_n.jpg
    http://sphotos.ak.fbcdn.net/hphotos-..._2310967_n.jpg
    inaadjust din namin ng tama wag sobrang baba wag naman naktaas
    eto pic ng avanza naka 50w 6000k h4 hi lo yan na xenon optics hid
    low beam yan
    http://sphotos.ak.fbcdn.net/hphotos-..._6582424_n.jpg
    eto high beam
    http://sphotos.ak.fbcdn.net/hphotos-...5_123745_n.jpg
    now eto pic ng low beam tignan niyo nalang yung cut off sa pader hindi naman nakataas eh hanggang hood lang nga ng lancer
    http://sphotos.ak.fbcdn.net/hphotos-..._1665391_n.jpg
    so yung sa eg na sinasabi ni sir garyq ba yun sir malamang hindi naadjust ng tama yan dapat ibalik sa nagkabit yan
    now dun sa philips na hid hehehe eto nalang tignan nyo maigi yung ballast ng philips at ballast ng xenon optics
    http://xenonoptics.com/HID/thumb/ballast-50W.jpg
    hindi lang yan meron pang mga marking dyan sa ballast para makita niyo similarities, actually yung pinagpagawan ng philips ng reg size ballast china na din. and ang hid namin ginamit ng toyota sa vios xx hehe so isipin niyo nalang ano gusto ko sabihin hehehe. pede niyo silipin ang ballast ko dito pwede ko buksan sa harap niyo just to see the similarities inside and out hehehehe
    pwede niyo din check comments and suggestion page sa website www.xenonoptics.com
    and gallery pero di pa complete gallery page namin hehe kakapagod mag resize ng pic kasi
    happy viewing
looking for best hid?
