Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Aug 2011
    Good Day mga tsikoteeers!
    Nag pa magic tint po ako ng nissan eagle pick up ko.sobrang madilim pag gabi. ano ba magandang ikabit dito? fog lights po ba or all weather lights?.
    bali naka DLAA 55W Halogen lang siya ngayon. ang dilim talaga pag gabi. i know the best suggestion is e pa cut yung tint or e patanggal pero sayang naman.di naman ako mabilis mag drive..hehehe.
    bali may naka install but sira na yung rectangular fog lights sa pick up ko balak ko lang palitan with the same rectangular size.
    ito plan ko sundin sana based from a nissan frontier bravado fog lights..ano po kaya ang specs nito?
    ano po bang ma sasuggest ninyo sir?
    Last edited by justinlorenz99; June 10th, 2012 at 01:08 AM. Reason: wrong pictures
    IMO focus po kayo sa HLs kasi wala masyado natutulong ang fogs. Get a good aftermarket halogen bulb like Philips XP/XV or Osram Nightbreaker. Just don't install plug n play HID on the HLs, maliwanag nga, nakakasilaw naman ng kasalubong. Or if the shade of your tint is too dark, have it removed and replace it with a lighter shade. HTH po.
    If light output is your concern, go with stock white bulbs. Philips Vision Plus or Extreme perhaps?
    How are your headlights? Did you try cleaning, upgrading the with a plug and play wiring (i.e. Narva kit + ceramic sockets) then use a 90/100w bulb? Did you also try working on the aim adjustment? Baka masyado mataas.
    Aug 2011
    Hay di rin pala maka tulong ang fogs and all weather.
    di ko pa na try ang 90/100W bulb. Hay malabo na kasi mata ko :D pero im using glasses. yes po i tried aim adjustment.ok naman. ang dilim lang talaga pag gabi kaya nasa 50-60kph na lang manakbo sa probinsya po kasi so expect na madilim.
    Salamat po pala sa mabilis na pag response sa thread ko.
    Sep 2011
    Kailangan HID talaga. Walang tulong yung fogs. Na try ko narin yung Philips at Osram, wala rin masyadong tulong, kaya ginawa ko, pinalitan ko tint, 1/4 lang nung windshield may tint.
    Aug 2011
    Quote Originally Posted by Harangody View Post
    kung HID po ano po ba maganda? can you give me the exact specs sir? and what are the pros and cons of this at saka ano po ba ang kakailanganin or safety measures to check before installing? pasensya na po medyo noob ako dito eh
    will try muna sa lightings pero kapag wala pa din i will just remove the tint na lang.kaso ang pangit tignan? if sa tint naman po ano po ba ma sasuggest ninyo para sa wiendshield at bagay sa color ng pick up ko?
  7. #7
    headlight lang yan sir, palitan mo ng mas maliwanag yung mga na suggest nila osram night breaker or philips vision, baka di ka pa sanay bagong lagay lang ba tint mo? ibabad mo muna sa araw mga 3 araw masasanay ka rin ;)
    Aug 2011
    Quote Originally Posted by cokezero View Post
    Mga 6 mos na po sir.kaso ngayon lang medyo madalas ginagamit sa gabi ang travel.
    Problema sa HID sabog output naman pag plug n play. Sa totoo lang di nakafocus sa kalsada ang pnp HID kaya better pa rin ang Osram NB or Phillips XV.
    Retrofit. Kahit stage 1 bolt on ni gary kung may budget naman
    Or IMO, high wattage bulbs na all weather para kahit umuulan kita mo
    Pero the best pa rin palit tint, labo na nga mata mo sir naka super black ka pa hirap talaga yan
    HIDs sir are not meant to be installed sa stock reflector HLs. Projector type HLs will give you the best light from HIDs kaso pricey na masyado. I see po na yung HL ng pickup nyo is glass pa. Nakalimot ko tawag. Hindi pa sya yung reflector type like most of the modern cars, so mas sabog po output ng HID dyan. Recommended lighting upgrade talaga is yung PXP or Osram NB or upgrade ng 90/100W bulb + ceramic sockets.
    Tint ko sir is 3M BC35. Lightest shade ng reflective tint ng 3M. Di ako kita sa labas pero parang halos walang tint ang view ko sa loob.
    Ay naka superblack ba? Medyo nalito ako sa name ng thread eh. If that's the case, talagang kahit anong ilaw pa yan kahit retrofit pa, balewala rin because of the superblack tint. Kaya ako kahit gusto ko nyan for heat rejection and privacy, di ako papakabit nyan dahil sobrang hirap makakita sa gabi, and pointless lang yung ilaw mo.
    Aug 2011
    hindi super black iyan... magic tint po iyan. 3M brand nakalimutan ko lang yung exact..yung picture po ng pik-up luma na po iyan. just a reference lang po sana iyan for the old fog lights.hehe.
    ito po latest pic ng pik-up with its new headlights
    DLAA LA8000HII
    headlight link
    UNIVERSAL FOG LAMP-LA8000HI-LA8000HII----Zhongshan DLAA auto parts industrial Co., LTD.
    pick up pic:
    Frost Yata tawag dyan
    Kung ako sayo imbes na gastusan ko hl bulbs ko bibili nalang ako bago tint para sa windshield, light lang
    Sep 2011
    Palitan mo na lang ng medium black or yung lightest shade. Hindi talaga recommended yung super black sa windshield.
    Tama yung mga nagsasabing palitan mo ng lighter shade yung windshield tint mo. Di rin kasi maganda magpalit ng mas mataas na wattage na bulb dahil nakakasilaw ito sa kasalubong mo na maaring maging sanhi ng aksidente. And, may grado pa mata mo, kahit walang grado ang mata mo, ang hirap magmaneho nang naka super black tints, lalo na't tag ulan na ngayon. Huwag ka manghinayang sa tint mo, mas importante yung safety mo.
    Aug 2011
    i would rather choose to change my tint na lang talaga mga bro. btw anong magandang tint na lighter na bagay sa color ng pick up? sorry medyo OT.
    Quote Originally Posted by justinlorenz99 View Post
    best solution with out annoying other motorist. anyway on all the cars i have owned usually lightest shade on the front then darkest on the rest.
    Mar 2012
    Tama lahat sinabi nila, ako naka Philips n xp pero d siya ganun kalinaw dahil may tint s harap, Kung gusto mo n d k mainitan pero malinaw na tint mag vcool ka, yung sa akin 3m n light shade pwede na
    *ts - tama sila better kung magpalit ka na lang ng lighter na shade ng tint. ikaw na din nagsabi na medyo malabo na din mata mo. kahit na naka-eyeglasses ka iba pa din yung vision mo especially at night. or if you want, palagyan mo na din ng grado yung windshield mo para 2 in 1 na... peace!
Fog Lights or All Weather Lights for a Magic Tint and Super Black Suggestion?
