Results 1 to 3 of 3
    guys help naman kung pano palitan yung bulb ng headlight ko..i'm trying to search dito sa forum na 'to and using search engine, pero wala kong nahanap eh.. hehe.. thanks for the help guys.. ^^
    Sir nasa Manual po yan ng car nyo pero mostly naman ng mga headlight assembly is huhugutin mo lang ung socket then ung rubber sealing and last is tatanggalin mo ung snap on lock sa bulb. All you have to do is to find a way to reach the back part of the headlight assembly, my iba kasi natatakpan or nahaharanangan eto ng ibang components. Hope that helps.
    if your car is one of the later models of any car make normally the socket will have a little grease on them to prevent rust and corrosion also prevent melting of socket due to spark caused by loose connection.
    so be careful when you touch the grease make sure you dont the touch the glass surface of the new bulb. as when it heats up its will cause some stain on the inside of your headlight.
    normally there are 2 metal one one metal holding the bulb in place so get a flashlight and look at the back portion first.
    oh before that make sure to remove the rubber cover or plastic cover for most hyundai and kia cars.
DIY in changing headlight bulbs...
