Results 1 to 6 of 6
    sa gabi lang naman pag turn ko headlight daytime driving ok lang may puna pa ako , parang may amoy mabaho under the hood pls help ,thanks in advance
    Jun 2005
    baka wiring mo
    better have your wirings check ASAP!!! You don't want end up in with a car in flames. could be just a loose wiring that could cause your connections to heat up.
    Dec 2004
    loose wiring, or if it's a second-hand vehicle, the previous owner might have removed the relay for the headlights and directly connected it to the switch.
    May 2005
    Quote Originally Posted by bambino
    .pa check mo na sa electrical shops..kung amoy sunog na insulator delikado na nga ,check mo din muna mga connections mo (sockets,wirings.etc) baka may nag loose ka lang
    Quote Originally Posted by BoEinG_747
    sir,sino ba mahusay electrcal sa menila? sa pasay ang home ko
headlight car ko  kukurap-kurap lalo na pag   accel ko
