Results 1 to 7 of 7
    [SIZE=3]Guys ask lang sana ako i want to replace yung stock halogen light ng nissan ko
    [/SIZE]
    [SIZE=3]please commit naman d2, which is better?
    [/SIZE]
    [SIZE=3]HALOGEN BULB H7 12V 130W SUPERWHITE YELLOW KOREA[/SIZE]
    or
    [SIZE=3][/SIZE][SIZE=3]HALOGEN BULB H7 12V 130W SUPERWHITE like HID KOREA[/SIZE]
    thank you very much
    better use Philips xtreme or Osram nightbreaker. stock 55/60w lang but 90% more light throw technology.
    Quote Originally Posted by my_nissansentra View Post
    [/SIZE]
    [/SIZE]
    or
    thank you very much
    +1 ako sa sinabi ni rion. isa pa, 130w ang isasalpak mo na ilaw, baka masunog naman ang wires mo. ang stock head light wiring ng mga sasakyan is designed for 60/55w bulbs. so kung 130w, maguupgrade ka into ceramic sockets or even palit ka ng mas matabang wire with a higher ampacity.
    so kung yan din lang, osram ka nalang, nightbreaker. maganda pa, mura pa...
    Pag superwhite, disadvantage nito, pag dumadaan ka sa kalye na naka ASPALTO, para kang walang ilaw (Black absorbs white, hence no light reflected to your eyes). Pag heavy rains, para kang walang ilaw (Water, refracts white light, too few light hits your eyes)
    Why spend more money to buy lights that have less lumens. Sayang lng yan.
    OK na yun Nightbreaker or Silverstar 50% more light.
    or
    thank you very much
    You might be happier if you got 90/100 watt flosser or bosch bulbs with regular color. They are brighter in any weather condition. You'll still need to use ceramic sockets and relays to avoid melting the wires. But the 100watt bulbs will be cooler to the headlight assembly which might start to melt or yellow if you used 130watt bulbs.
    Thanks guys .... i will use nightbreaker for sure more cheaper and more lights.
    Thank you so much. God Speed
    [/SIZE]
    [/SIZE]
    or
    thank you very much
    hanap ka ng philips pero kung namamahalan ka try mo osram or flosser na halogen mga 100w lang pwede na mainit sobra 130. you might need to replace your socket to ceramic ones. then pa relay mo na. pero pag mitsubishi yan i believe naka relay na yan
Halogen?
