Results 1 to 17 of 17
    Mar 2004
    I'm a newbie when it comes to car electronics. I'd like to know if installing HID on my 95 L300 van is possible. Please advise. Thanks!
    ur l300 van is not equipped with projector type lamps... so it is a NO for me.
    Mar 2004
    Quote Originally Posted by mazdamazda View Post
    Is there no other way to rectify this? I need HID's so I can see better when driving at night.
    :question:
    nope... unless you want to blind other motorists and be featured in the Goon Squad
    you can install aux driving lamps instead...
    Quote Originally Posted by Babnoy View Post
    :question:
    try to remove your dark tint on your windshield
    just kidding po! if you don't have a projector type headlamp, eh mangsisilaw ka lang ng kasalubong mo. try to read the FAQ thread re: HID
    +1 on toybeats... if you have dark tints up front... remove them. :lol:
    Mar 2004
    So it is possible to install HID in an old running van
    Oct 2003
    Go for it! i'd like to see original HID's on an L300.
    it is possible... but as I've said, you'll be blinding incoming motorists and annoy the vehicle in front of you which is just plain irresponsible.
    Sep 2004
    Want to see better at night? First of all, take better care of your eyes, and eat more nutritious food. Second, remove/replace ultra dark windshield tints, if any. Third, just install auxiliary lighting.
    Aftermerket HIDs should NEVER be an option, IMO. And they should be banned, period.
    Mar 2004
    *Toybeats: I do not have any tints on my windshield. It's just that I'm sufferring from poor night time visibility due to the degraded performance of my van's headlight.
    *Mazdamazda: I know but don't worry, I seldom use the van at night and only use it during daytime.
    May I ask if there are other "special" equipment or things needed to do prior installation of HID since i'm using an old school vehicle?
    TIA
  12. FrankDrebin Guest
    Yup. It is possible but it will also give you the same result when you upgrade it into a higher wattage bulb. Sayang lang. Ang problema kasi dito ay yung lens.
    Here's cheaper solution
    1. Replace the lens with a clear type ones.
    2. Use an all-weather bulb. Install a relay or upgrade the wiring.
    Mar 2004
    Quote Originally Posted by FrankDrebin View Post
    Oh my...you've hit the nail on the head!!! I guess you're right!
    no offense po, but they are right about HID w/o projector type lamps.
    indeed.
    MABE you can improvise and fit your van with a light with projector lamp.
    or MAYBE you can improvise and make a hole in your bumper, install a projector.
    nakakasar din yung white bluish bulbs without HID peru always naka high.... dahil mahina sa kanilang panignin, peru sobrang liwanag sa incoming motorist.
    You could try changing your bulbs to Philips VisionPlus or Osram Silverstars. They're both stock wattage but their light throw's wider and farther. Just right for drivers with poor eyesight.
    Dec 2003
    are your headlights the same as the rectangular sealed beam types? if so then you can buy the semi-sealed beam clear types with h4 bulbs, ito sigurado tataas visibility mo as compared to old sealed beam lamps.
    Mar 2004
    Quote Originally Posted by BlueBimmer View Post
    Hi BB! Yes you're correct. Where can I possibly buy this clear semi-sealed beam with h4 bulbs?
Is it possible to install HID to my 95 L300 van?
