pna-check ko yung kalampag ko. sabi daw one of the causes is yung steering bushing. dati pinalitan ko ko ito, plastic yung nilagay. after sometime nasira ulit ito. sabi nila eh mas ok daw machine shop na ito.
it really depends on the bushing but in some cases you have to send the bushings to the machine shop to have them pressed in/out before installation. baka ganun yung sayo. try to get a 2nd opinion muna tho before you have the work done
If the steering wheel does not feel loose if you bang your hand on it, the kalampag is probably coming from somewhere else. Have you tried checking your shock bushings? You can check these by raising the car on a jack and try to move the shocks with your hand/s.
tama ang mga gurus, but i think you also need to check yung mga tie rods din. saka yung mga rubber bushings sa rear suspension. dati nagkaroon din ako nang ganyang problema. medyo me kamahalan nga lang ang mga parts, kasi lahat pinalitan ng bnew.
