Results 1 to 13 of 13
    Anyone notice how when their cars were new parang very fuel efficient tapos as it gets older parang sumasama?
    I (just) noticed this on my 2002 Civic Vti. Dati umaabot ako ng 13+ kms/liter pag mostly hiway at naka-blaze na gas. Ngayon parang hirap na ako umabot sa 11. And I think my previous cars also behaved similarly -- another civic and a lancer. Ngayon ko lang na-realize kasi medyo bigla dahil last year yakang yaka ko pa mag 12+.
    Dati naman nakamana ako ng 8 year old car (colt) and while hindi siya ganun ka efficient to begin with, parang hindi ganun kalaki ang degradation after 3 years.
    Ganun kaya talaga? That FC degrades on a decreasing slope as a car gets older? Sa inyo gano kalaki ang degradation as the vehicle gets older?
  2. #2
    There are a lot of factors - Maintenance, Driving Habbits, Traffic Conditions, etc.
    The best thing you can do is to maintain your car religiously to maintain peak performance. Have a look at the maintenance booklet to guide you on your maintenance schedule.
    Jul 2006
    Wear and tear lang yan. A tune up should bring it back to spec.
    You can't expect a car to maintain itself. Well, if you have a diesel, it will maintain its fuel economy to some extent too and it's mostly consistent with diesels but gas cars have a lot more things to break down that can lead to increased fuel consumption.
    Oct 2004
    ano po ba ginawa from your last tune up?
    When was the last time your valve tappets were adjusted?
    Mar 2005
    kapag bago ang tsikot maingat ka pa, kaya fuel efficient
    kapag luma na, birit na hehehe
    Nov 2006
    ...just like what everybody else recommended, a tune up.
    if you haven't done so... check your air filter, spark plugs, spark plug wires, distributor cap and rotor (unless your car has DIS), O2 sensor/s, clean your injectors (fuel tank additive/fuel sys cleaner should do the trick) and maybe an oil change and a fuel filter replacement (depending on the mileage)
    and refrain from flooring the throttle or eve better, tulak mo na lang j/k
Fuel Efficiency Degradation?
