Results 1 to 20 of 20
    Jun 2007
    want to get more power from yuor turbo diesels? simple upgrades range from getting a more free flowing exhaust and after market type filters,this will give yuor engine more air to breath and expell..just like inhaling and exhaling..it will not only give yuo more power but also give yuo more mileage..as for the crdi engines get a good ecu upgrade it will fine tune yuor engine more,giving yuo more power..and still if not enough we would like to introduce to yuo water methanol injection or boost cooler..it is applicable to all kinds of turbo diesels from 4-8cylinder..with or without intercooler..water and meth is sprayed into the engine in a mist form cooling the intake charge,it is practically safe ,,its been used by top diesel pick ups in the usa in their diesel truck challenges..i have tested this system in my fort and yuo can really feel the power it gives,,.for more info just pm me.
  2. #2
    do the washer mod, lalo na kung old-school turbo diesel ka..(2c-turbo, 4d56t, sd33t, td42t, td27t, basta non ecu-related turbo diesels) cheapest mod yan..
    lytspid,
    ...."we would like to introduce to you water methanol injection or boost cooler..it is applicable to all kinds of turbo diesels from 4-8cylinder..with or without intercooler..water and meth is sprayed into the engine in a mist form cooling the intake charge."
    How does this work?
    Does the water methanol mist go inside the combustion chamber?
    How and where do you install the injector/s?
    Jun 2007
    sir 4j, the systems work on load sensing basis,it has its own computer which yuo can adjust depending on which starting boost it will start injecting and the maximum boost ..it has also its own nozzle and boost pressure sensor, the nozzle is installed before the throttle body of yuor engine,,it sprays water and methanol mixture inside the combustion chamber through the intake cooling the intake charge.. the water/meth is in a mist form and not in form of droplets..it is evaporated by the air before it reaches the combustion chamber..the cooling effects allows more air to be crammed inside the engine and also at the same time the steam will clean the carbon deposits inside the engine.the methanol with in the water will boost the burning of the diesel fuel thus giving yuo more power..the system is also equip with an on-off switch where yuo can turn it off when not in used..and a led light so u will know that it is operating when in boost..
    Interesting!
    Where do you store the water methanol mixture?
    When is it ideal to activate and di activate the system?
    In a liter of diesel how many ml. of water/meth will be used?
    How much is a liter of water/meth?
    Aug 2003
    4JG, water charging was used to boost diesel powered tanks during WW1, although the system of delivering the water charge was not as sophisticated as what lytspid described. and it was just water then, not a water/meth mixture. (just read it somewhere before but i cannot remember where exactly...)
    Jun 2007
    sir 4j, the system is equip with its own reservoir ,pump,vc controller,switch and everything needed in the installation,activating the system depends upon the user,just like NOs theres a switch when yuo want the system to function and a led indicator when yuor in boost..when the system is on, the vc controller relies on the boost level when to start spraying,boost levels are user programed yuo tune the controller when to start ex.6psi and maximum of 25psi..this will allow the controller to spray water and meth starting at 6psi and stops at maximum 25psi..usually it is addicting when yuor under meth(water/methanol)if yuo love speed, coz yuo will really feel the power it produces when the system is activated..the power it produces depends on yuor mixture..we have an exact measurement for each horsepower yuo want to get..it has a manufacturer claimed of 30-90hp depending on mixtures,,the system is made and tested in the usa and has a lifetime warranty..if methyl alcohol is not available yuo can also use denatured alcohol as a substitute..
    Jun 2007
    pwede ba na gamiton sa 2002 strada? tia
    Thank You Lytspid and Diesoline.
    Marami ako natutunan.
    Please balitaan mo kami on this.
    Especially doon sa mga units that you have actually installed.
    looks like its beneficial only to Diesel racer fans not really for fuel economy.
    atleast this is not some kind of another fuel saving gadget.
    please let us know any updates indeed. thanks
    Jun 2007
    *everester62...sir,pwede kaayo...applicable sya sa tanan turbo charge diesel engine.. mka htag sya extra power..
    --- concerning the units that we have installed this system , they are enjoying the benifit of having extra power when they wanted to,also the added benifit on having this system is everytime yuo use it yuo are having yuor combustion chamber being steam cleaned so yuo have less carbon deposits,less carbon in yuor oil and yuo will have longer change oil intervals..as i have been using it my fort there is nothing else compares the power it added once the system is operating..it also lowers yuor exhaust gas temperature ..high EGT's is the number 1 factor that affects turbo life and the performance of each engine yuo can expect also a 3-5 psig boost increase when using the system...this system is used in the USA by top diesel trucks owners for many years now and no complain of having any problems in the engine.
    Quote Originally Posted by lytspid View Post
    how long one filled up last? does it mean the more we used it the more we refill it...
    Jun 2007
    it depends on how often yuo use it,so the more yuo use it the more u refill ...it also depends when yuor engine is in boost and yuor setting for the system to start operating.
    Lytspid,
    Maybe you can set up a demo for the tsikot diesel peeps.
    Jun 2007
    un sna mgnda kso nd2 sa davao ang fort ko,,newi e2 un pix installed in my fort.. the 1st pix is un pump with reservoir, 2nd is un installed nozzle sa intake manifold...
    I see.
    There will be a motorshow here in Manila, maganda sana kung may flyers ka maski sa mga parked diesel vehicles.
    Jun 2007
    sir 4j, hopefully aabot din sa ganyan, and also we will have one vehicle na ggmitin sa motorshow and we will invite a representative from the manufacturer to really explain and give demo on diffrent set ups using the system..sa ngyon we are still scouting for interested buyers so we can purchase the system at once,pra nka reserve na agad ang system sa persons na omorder...
    Jun 2007
    Good day sir lytspid ask po lang ako magkano kaya ang cost kung bibili ako yng pang diesel upgrades? thank you.
    Jan 2003
    Is the injector after the MAF?
    ads are not allowed here.
    :fyi:
turbo diesel upgrades,get more power
