I'm quite tired of the noise of my diesel and would like to quiet it up a little... (actually a lot).
Oh, my car is a 200D W123 Benz BTW.
I've just applied acoustifoam underneath the hood and it did reduce some ambient noise from the engine bay (although my plan was to apply asphalt sheets first before acoustifoam oh well, nagmadali eh), but god knows most of my noise is coming from the firewall, fenders and transmission...
I'm not expecting it to sound like a gasser but at least like a early 90's pickup would be fine.
The W123 firewall is quite thin and di sya double layered like the 126/124 or later variants...
I do understand that some of my small rust holes on the driver side is attributing to the noise. But most of the noise is coming from the said panels talaga.
I'm set to apply asphalt sheets on the firewall, transmission "hump", rear seat (backrest and seat) then layer a sheet of acoustifoam on top of it after I get the all my leaks fixed.
So here are my q's...
1) How can I remove the fenders or at least gain access to it's back side? Sa Japs it's quite easy, just remove the plastic fender plastic ok na... How about the 123s? I'm thinking of spraying ample amounts of thick-type undercoating material then clearcoat it for sealing.
2) How "cluttered" is the firewall (cabin side) of the 123? Dami ba nakaharang?
3) Do you guys know a cheap place to replace the 123 headliner? Heck, right now, I don't care if it's orig or not, the original perforated ceiling is quite expensive. OK na sakin kahit velour/fabric type.
4) How much will it cost to replace my tailpipe? Again, doesn't have to be orig, madami na leaks sa muffler eh.
5) Last na, promise... I tend to "hear" a lot of outside noise coming in from my windows and/or door seals (edges), is there anything I can do to reduce this? I can hear outside noises quite easily even if I'm not moving. If you're having a normal conversation outside, chances are I can hear you if you're talking within 2ft from the car.
I know I'm being picky here since my 200D has served me really well since I've got it, but noise is not something I tolerate, mas ok na sakin mabagal than noisy hehe.
Thanks guys.
