Results 1 to 15 of 15
    ok lang ba gawin to...kasi right now sabi nung owner premium daw nilalagay eh its 5 pesos more expensive so Im just wondering if pwede magswitch to the low budget unleaded?
    What vehicle is that and what engine? Unless the manual specifies using high octane, regular unleaded should work just fine.
    Quote Originally Posted by workaholic View Post
    Typically it will be fine to use unleaded gasoline. Generally it depends on the car's engine type but unless you are driving a high performance car, it would run well on unleaded.
    1.3 nissan sentre f.e pero 16 valve sya... so pwede ba i unleaded nalang?
    pwedeng pwede yan... mas tipid pa nga ang konsumo... 87 RON nga lang yata ang requirement nyan e..
    Aug 2004
    Yeah, we used to run our FE on regular unleaded.
    Hay salamat...kailangan ko bang idrain muna yung gas or ok lang na hindi???
    no need to drain.. just "fill it up!" sabi nga ni Jose. pero wag Diesel Maxx ha..
    actually, with that engine, it will run the same with unleaded or premium gasoline. No performance gained if you used better gasoline.
Gas Question changing from premium to low budge unleaded
