Ano difference ng SRS Airbag sa Airbag ABS?
airbags are suplemental restraint system (SRS) for passengers
anti lock braking system (abs).
airbags and abs are saftey features of the car.
there is no such thing as "airbags abs"![]()
Airbag is the layman's term for SRS (supplemental restraint sytem). As the name implies, it is SUPPLEMENTAL. It supplements the seatbelts which are the PRIMARY restraint system.
ABS (anti-lock braking system) prevents your wheels from skidding in a panic stop allowing you to brake AND steer at the same time. However, ABS is not designed to reduce stopping distances in most panic situations. It just enables you to steer while braking. Driver training is still required to maximize the use of the ABS system.
SRS Airbag = used by most marketing material to indicate that the car has an airbag.
Airbag ABS = used by most marketing material to indicate that the car has both airbag & abs.
Akala ko groundbreaking technology na yung Airbag ABS...hehehe.
Airbag/ABS siguro ang nakalagay sa marketing material
I think Airbag ABS has a built-in antilocking mechanism para hindi ma-stuck ang deployment ng airbag.
hmmm, ok yun di ba M54?
